Hi all,
Recently i've been having quite a few inconsistencies in the performance of my NAS, specifically it will freeze very often, for 2-20seconds then resume normally. Everything gets frozen, any file transfers, VMs, jails, even the Truenas GUI
I have a sneaky feeling this is related either to my ssd pool or the mobo's realtek NIC.
Here are the pc specs:
The system has these drives:
The SSD_Pool runs 3vms
I've tried running a htop & iotop commands on all three vms but can't pinpoint anything to the freezes.
This may or may not be related but i was reading this thread Device is causing slow io on SSD drive? where Patrick M. Hausen noted that sata ssds could be bottlenecking/chocking the system ?
Historically, when i restart the heavy VM, the situation seems to get better for a short period of time before going back to freezing often.
As mentioned, when the system freezes, even the UI is frozen so i can't see much, but once it unblocks, i can see the CPU saw a small spike in Interrupts, and ofc the network IO goes to 0.
Today, and the reason I've come to post here for help, there was a big spike, and even got an alert from the server
Device /dev/gptid/04349e2f-0c81-11ee-8b50-2cf05de61ea9 is causing slow I/O on pool SSD_Pool.
Theres nothing on the smart test to signify any further issue.
Here is the pool disk reports from at that time
Is there anything i can run to further debug this issue ? Worth reducing cpu/ram on vm ?
Open to any suggestions/help, i'm pretty new to the whole eco system.
Thanks for your time,
Nicholas
PS, and this may be irrelevant, I've noticed that the SSD Pool seems to hit 100% usage quite often, every 15-20mins but doesn't necessarily line up with the freezes. (Why is it often both disks at different times ?)
- cpu: ryzen 5 3600
 - memory: 64gb ddr4
 - mobo: msi B450 TOMAHAWK MAX II (Realtek® 8111H Gigabit LAN controller)
 - pci: Realtek RTL8125B 2.5gbe for direct link to pc
 - pci: Dell PERC H200 (flashed IT)
- Direct mobo sata:
- 2x250gb ssd mirror boot drive
 - 4x8tb hdd (WD Red pro) raidz1 Tank pool
 - HBA:
- 4x16tb hdd (exos x16) raidz1 Tank pool
 - 2x500gb ssd mirror SSD_Pool
truenas#    zpool    list    -v
NAME    SIZE    ALLOC    FREE    CKPOINT    EXPANDSZ    FRAG    CAP    DEDUP    HEALTH    ALTROOT
SSD_Pool    460G    55.7G    404G    -    -    21%    12%    1.00x    ONLINE    /mnt
    mirror-0    460G    55.7G    404G    -    -    21%    12.10%    -    ONLINE
    gptid/04444716-0c81-11ee-8b50-2cf05de61ea9    464G    -    -    -    -    -    -    -    ONLINE
    gptid/04349e2f-0c81-11ee-8b50-2cf05de61ea9    464G    -    -    -    -    -    -    -    ONLINE
Tank    87.3T    64.4T    22.9T    -    -    12%    73%    1.00x    ONLINE    /mnt
    raidz1-0    29.1T    23.4T    5.67T    -    -    19%    80.50%    -    ONLINE
    gptid/2ba46015-18bf-11ed-9bbf-2cf05de61ea9    7.28T    -    -    -    -    -    -    -    ONLINE
    gptid/2ba076b3-18bf-11ed-9bbf-2cf05de61ea9    7.28T    -    -    -    -    -    -    -    ONLINE
    gptid/2ba250b6-18bf-11ed-9bbf-2cf05de61ea9    7.28T    -    -    -    -    -    -    -    ONLINE
    gptid/2ba35dac-18bf-11ed-9bbf-2cf05de61ea9    7.28T    -    -    -    -    -    -    -    ONLINE
    raidz1-1    58.2T    41.0T    17.2T    -    -    10%    70.50%    -    ONLINE
    gptid/9589f772-0c86-11ee-8b50-2cf05de61ea9    14.6T    -    -    -    -    -    -    -    ONLINE
    gptid/956f2cc9-0c86-11ee-8b50-2cf05de61ea9    14.6T    -    -    -    -    -    -    -    ONLINE
    gptid/95821028-0c86-11ee-8b50-2cf05de61ea9    14.6T    -    -    -    -    -    -    -    ONLINE
    gptid/957ad862-0c86-11ee-8b50-2cf05de61ea9    14.6T    -    -    -    -    -    -    -    ONLINE
boot-pool    222G    3.03G    219G    -    -    0%    1%    1.00x    ONLINE    -
    mirror-0    222G    3.03G    219G    -    -    0%    1.36%    -    ONLINE
    ada1p2    222G    -    -    -    -    -    -    -    ONLINE
    ada0p2    222G    -    -    -    -    -    -    -    ONLINE
- 1 super light just runs pihole (1core 1gb ram)
 - 1 light just runs vpn & prowalar (1core 2gb ram)
 - 1 heavy runs *arr suite, and qbittorrent (3cores 24gb ram)
Nicholas
