Some Apps Won't Deploy - I'm on Bluefin
Zain
I'm having an issue where select apps won't deploy. I'm getting the following error in the app shell;
error: cannot exec into a container in a completed pode; current phase is Failed
TrueNAS-SCALE-22.12.0
It was working, but had to perform a restart to take care of another issue.
TIA,
Zain
Zain
Also, Plex specifically will not deploy at this point either. Shell shows the following for the official app:
error: unable to upgrade connection: container not found ("plex")
mraw435
hi! i ran into the same issue for a second and the solution that worked for me:
Go to Apps -> Settings -> Advanced Settings
Leave the Route v4 Interface and Route 4 Gateway blank and press save..
Go back to the Advanced Settings page and and readd your interface and Gateway....essentially resetting everything.
Zain
Those are already blank.
This is still an issue for me. From pod shell:
Please help. TIA
mraw435
Please help. TIA
if it is already blank then go ahead and fill it in -- Set Route v4 Interface to eno1 (or whatever interface you have set up located at Network -> Interfaces. Then set your Route 4 Gateway to your router IP.
save and then reboot (<---edited post to add this statement)
Zain
Yeah that fu**ed all my apps.
Edit- gaver the ol reboot, seems to work again, for now.
