[solved] WebGUI not reachable after mtu 9000
icewaere
i have a little problem with webgui access freenas 9.3 ;/
i have set on webgui networksettings options:mtu 9000
now i cant access Webgui ;/
i have try to edit /etc/rc.conf but is empty ;/ and ifconfig em0 ip mtu 1500 but dont change that ;/
i have reset network interface and config new with VNC shell but dont works to change mtu to 1500.
wich file i must edit to change network options to del mtu 9000?
hope anyone can hlp me without setup freenas new for this little misstake.
regards ice
Uh.. the two ways I know of are to default you system, or setup a temporary network that does handle the mtu 9000 and log into the FreeNAS server and remove the extra MTU setting.
Noctris
Do you have physical access to the machine? You could fix it through ifconfig or worst case delete the interface and reconfigure?
Sent from my portable microwave
Noctris
Noctris
"ifconfig em0 mtu 1500" (if it's em0).
By the way, I hope you're not using that as a hat.
Nah.. just keep it to my ears from time to time when i feeld cold :)
icewaere
thx for all response!
i can fix it with VNC shell access ;)
after that i have access again to WebGUI and can delete the wrong Interface Options ;)
regards ice
