Firstly, due to personal reasons, my current NAS setup was never fully completed upon last rebuild, adding all the email stuff for alerts and scripts etc. That was my bad, but I just wasn't using it either, until recently. So I had undusted the box to try get a good working Plex setup again, and everything was going fine until i logged into the webUI this week and say an alert saying my pool was degreaded:
I had a spare same model/size RED at hand and without really thinking (because I've done it once before a while back), i just shut down the box, removed the drive, replaced it and started the box back up thinking to just go into the webUI and choose replace/resilver like i remembered doing.
But that option wasn't available ANYWHERE I could see, including where the few guides online i could find mentioned it should be. Something I read said i should mark the problem drive as "offline" and then shutdown/replace, so I put old drive back and did that, although, there were no errors once i put the old drive back in and the pool was marked as healthy in the webUI (presumably because it does that until tests or whatever show it as problem again). But anyway i marked as offline, shutdown, put new drive back in, booted up, and still there was no replace/resilved option anywhere i could see.
So, I did that and I see it says to mark it as online which I've done:
But now if I try the same format/syntax I get this:
I tried all three versions of the device name that I seemed to have and that had just worked to put the HDD online with, but none work.
Something isn't working as intended here, that much I know. I remember the process being much simpler and smoother when I did it in the 9.3 or so days.
Can someone point me in the right direction please?
Thanks, and I've tried the be as thorough as I can be, but let me know if you need more information.
New alert: * Pool store state is DEGRADED: One or more devices has been taken offline by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state. The following alert has been cleared: * Pool store state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. Current alerts: * Pool store state is DEGRADED: One or more devices has been taken offline by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state.
# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:25 with 0 errors on Fri Nov 8 03:45:25 2019
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
pool: store
state: DEGRADED
status: One or more devices has been taken offline by the administrator.
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub in progress since Thu Nov 14 20:28:14 2019
2.64T scanned at 1022M/s, 1.20T issued at 464M/s, 7.52T total
0 repaired, 15.96% done, 0 days 03:58:10 to go
store DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
12255453197370737536 OFFLINE 0 0 0 was /dev/gptid/7f8fe6ab-6033-11e9-a8ab-7085c27b080f
gptid/99ac35ed-9886-11e8-8e34-7085c27b080f ONLINE 0 0 0
gptid/2078e43f-c25b-11e2-a8b0-60a44cae968d ONLINE 0 0 0
gptid/210199da-c25b-11e2-a8b0-60a44cae968d ONLINE 0 0 0
gptid/218ba2d5-c25b-11e2-a8b0-60a44cae968d ONLINE 0 0 0
errors: No known data errorsSo, I did that and I see it says to mark it as online which I've done:
# zpool online store gptid/7f8fe6ab-6033-11e9-a8ab-7085c27b080f warning: device 'gptid/7f8fe6ab-6033-11e9-a8ab-7085c27b080f' onlined, but remains in faulted state use 'zpool replace' to replace devices that are no longer present
# zpool replace
missing pool name argument
usage:
replace [-f] <pool> <device> [new-device]
root@freenas[~]# zpool replace store gptid/7f8fe6ab-6033-11e9-a8ab-7085c27b080f
cannot open 'gptid/7f8fe6ab-6033-11e9-a8ab-7085c27b080f': no such GEOM provider
must be a full path or shorthand device name
root@freenas[~]# zpool replace store 7f8fe6ab-6033-11e9-a8ab-7085c27b080f
cannot open '7f8fe6ab-6033-11e9-a8ab-7085c27b080f': no such GEOM provider
root@freenas[~]# zpool replace store /dev/gptid/7f8fe6ab-6033-11e9-a8ab-7085c27b080f
cannot open '/dev/gptid/7f8fe6ab-6033-11e9-a8ab-7085c27b080f': No such file or directory
