So, I've got Nextcloud Truecharts 25.0.2_19.0.51 up and running in SCALE 22.12.2. All working 100%, behind HAProxy.
But, on the Administration page security setting check, it shows:
<ifModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=31536000; includeSubDomains; preload"
</ifModule>
But on restarting the Nextcloud app, the security note remains.
I'm aware there's a similar thread, with the same question here:
www.truenas.com
But an answer wasn't forthcoming. If TrueCharts is setting that header in their app, it's not effectively being picked up by Nexcloud.
- The "Strict-Transport-Security" HTTP header is not set to at least "15552000" seconds. For enhanced security, it is recommended to enable HSTS as described in the security tips ↗.
</ifModule>
Fixing The "Strict-Transport-Security" HTTP header is not set to at least "15552000" seconds.
I am new to Truenas Scale. This is my first time setting up a server. I am using Nextcloud and have managed to access it remotely and securely using Traefik and Cloudflared. However, when I login to Nextcloud and check the Overview tab, I get the The "Strict-Transport-Security" HTTP header...
