lucv
- Mar 7, 2024
Thank you kind sir, testing now!By not setting it up there at all. The SSH connections configured there are intended for use with ZFS replication and possibly other backup tasks (hence being under "backup credentials" in the GUI), not for a straightforward SSH terminal session.
The GUI way to set this up would be:
- In System Settings -> Services -> SSH
- Make sure it's turned on and enabled at boot
- In Credentials -> Local Users -> root
- Paste the SSH public key into Authorized Keys
- Check "SSH password login enabled"
*IT WORKED! <3
