[Solved] Migrating TrueNAS - Trouble with Network
rakor
Hi there,
I want to migrate my TrueNAS Core, which is running on a HP Microserver to a Provmox VM. I was not sure if the thread sould pe posted to Virtualisation or here, but as I think it is not a vm-specific issue I put it in here. Please move it if I was wrong.
I installed TrueNAS inside the VM, saved the config on the hardware-based-installtion and uploaded the config in the vm. This went all fine.
My problem is that I can not adjust the network settings.
On my hardware-box I had:
NICs: igb0-igb3
LAGG: lagg0 (using igb2 & igb3)
VLANs: vlan10 (using lagg0); vlan90 (using lagg0)
bridges: bridge10 (using vlan10 and having an IP), bridge90 (using vlan90 without IP).
vlan90 ist currently not in use.
The vm has 2 NICs (vtnet0 and vtnet1).
But I can not change the network-setting on the console as everytime I try it the restart of the networking and routing fails.
I can open a shell and activate a interface using:
# sysrc ifconfig_vtnet0="DHCP"
# dhclient vtnet0
And then I can access the GUI using the provided IP.
But in the GUI I can't change the network-settings too. I can change all the stuff I want (remove devices, set settings, etc.), then click the test-button, but there is only the spinning circle telling me to wait. If I refresh the website all settings are set back. I want to adjust all the settings to my wish.
Do you have any hint for me where to look at?
Thanks a lot
Perhaps start by sharing the ifconfig output from the VM, maybe there's something that will give a clue to it in that.
rakor
So, now I did a rollback. The system is now installed and the config is uploaded. The system did a reboot. I haven't tinkered at the settings right now to have a clean state.
ifconfig tells me this:
If I select the first Option in the TrueNAS CLI-menu I get:
When I got the GUI running using ifconfig (as explained in my first post), the gui showed even the igb0-igb3 interfaces.
I still don't get what's happening physically there to make that a possibility... can you run through how you have told proxmox to connect the NICs to the TrueNAS VM?
And do they show up in lspci?
rakor
Hey there, now it is running... I did what I (thought) I did all the times before. If someone comes here later I'll show my way.
1. Create a VM im Proxmox and install TrueNAS (if vlans are necessary they can be set up in Proxmox, so we need no vlan-handling inside TrueNAS)
2. Export the setting in the old (hardware) TrueNAS-installation
3. Import the settings in the new (Proxmox) TrueNAS-installation (TrueNAS will reboot twice to aktivate the settings)
4. Open the CLI of new Installation
5. Open a shell and set networksettings for the vtnet0-device (for my infrastructure `ifconfig vtnet0 inet 10.10.10.10/24 up`) - Now the system was avaliable via gui.
6. Login via GUI and open the Network -> Interfaces.
7. Delete all vlans, obsolete interfaces, lagg-devices
8. If we need a bridge (I do as I have some jails running) set the corresponding interfaces (vtnet) to the bridge. For me vtnet0 (for vlan10) is a member of bridge10.
9. set an IP-adress. for the bridge10.
10. remove all IP-adresses from the interfaces (vtnet).
11. test the network-settings (now it was working as expected).
12. confirm the network-settings.
13. Insert the drives (via PCI-Passthrough).
14. Be happy.
Thanks for your advice ans patience. I don't know why it was not working the first 4 times, but I am happy it is running now!
