Dennis Lovelady
 - Apr 6, 2016
Receiving the following error:
when trying to check for updates. (This is after about a 30-second wait, which sounds a lot like a DNS problem.)
From the same FreeNAS system, in a shell, if I execute "ping update-master.ixsystems.com" I get immediate responses, no issue at all, so I know that at some level the system can resolve the name.
I also know that, from a local browser, I can access https://update-master.ixsystems.com/FreeNAS/trains.txt :
So it seems then network in general has no problem with the site. So it sounds (to me) like this issue may be limited to the GUI. But beyond that, I'm at a loss.
This worked until a couple of weeks ago. In that time, two things have changed: Upgrade from a prior 11.3 version (-u3, I think), and a change of internet service provider.
Any ideas?
Note: I suspect this relates to the problem that I cannot create new jails (see https://www.truenas.com/community/threads/cannot-create-new-jail-no-releases-entries-in-list.92798/). That issue (which has had no replies) has a similar but different complaint:
Unable to connect to url https://update-master.ixsystems.com/FreeNAS/trains.txt: Automatic update check failed. Please check system network settings.
FreeNAS-9.10-STABLE Release train for FreeNAS 9.10. Legacy, now in maintenance mode. FreeNAS-11-STABLE Release Train for FreeNAS 11.1 [release] FreeNAS-11.2-STABLE Release Train for FreeNAS 11.2 [release] FreeNAS-11.3-STABLE Release Train for FreeNAS 11.3 [release] TrueNAS-12.0-STABLE Release Train for TrueNAS 12.0 [release] TrueNAS-12.1-Nightlies Nightly builds for TrueNAS 12. Development version, for testing only. [nightly]
Any ideas?
HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by ProxyError('Cannot connect to proxy.', NewConnectionError(': Failed to establish a new connection: [Errno 60] Operation timed out')))
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
    raise err
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
    sock.connect(sa)
TimeoutError: [Errno 60] Operation timed out
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 662, in urlopen
    self._prepare_proxy(conn)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 948, in _prepare_proxy
    conn.connect()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 334, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
    self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x832ce0a50>: Failed to establish a new connection: [Errno 60] Operation timed out
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
    method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by ProxyError('Cannot connect to proxy.', NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x832ce0a50>: Failed to establish a new connection: [Errno 60] Operation timed out')))
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
    io_thread=False)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1098, in _call
    return await run_method(methodobj, *args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1022, in _run_in_conn_threadpool
    return await self.run_in_executor(self.__ws_threadpool, method, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1010, in run_in_executor
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 674, in releases_choices
    choices = {str(k): str(k) for k in ListableReleases(remote=remote)}
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/release.py", line 46, in __init__
    self.eol_list = IOCFetch.__fetch_eol_check__()
  File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_fetch.py", line 114, in __fetch_eol_check__
    req = requests.get(_eol)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.7/site-packages/raven/breadcrumbs.py", line 341, in send
    resp = real_send(self, request, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 510, in send
    raise ProxyError(e, request=request)
requests.exceptions.ProxyError: HTTPSConnectionPool(host='www.freebsd.org', port=443): Max retries exceeded with url: /security/unsupported.html (Caused by ProxyError('Cannot connect to proxy.', NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x832ce0a50>: Failed to establish a new connection: [Errno 60] Operation timed out')))
