Snapshots / Windows Shadow Copy Problem
FlyingBuzz
I got a idea what the problem might be:
/mnt/FileServerPool/NFS/Departments/Texas/Marketing
works because the length is 52 chars
Once it goes to 53 chars in length the shadow copy doesnt show up anymore
/mnt/FileServerPool/NFS/Departments/Texas/OrderEntry
Is there a way to fix this problem?
is "NFS" for the NFS protocol?
Hmm...I don't have any recommendations. :(
I tried to setup Shadow Copies myself and I couldn't do it :(
FlyingBuzz
thanks, I decided to redo a bunch of names to make it shorter so I would not have the problem anymore,
/mnt/FileServerPool/NFS/Departments/California/CustomerService to /mnt/FileServerPool/Branches/CA/CustomerService
Now I should be able to use previous versions for all the folders I had because the longest one is now under 53 chars.
I hope what I discovered was correct and everything will show the shadow copies now.
FlyingBuzz
It seems like the shadow copies are showing, so it really is something to do with over 52 chars for the problem to happen.
