TrueNAS Core gives the option to delete all snapshots, but SCALE only allows 100 at a time. Infuriating if you have thousands. Any ideas? I don't want to have to resort to the command line ideally
Making snapshots is very cheap, but deleting snapshots is quite expensive and requires metadata changes.
I assume this is a mechanism that has been added to avoid system performance issues. It should be documented or configurable... I'll check with the (very busy) engineering team.
Good morning chaps, thanks for the reply. Yeah, i know that the shell is probably the best option, but i'm not super au fait with the command line stuff, and just wondered why it was so easy on Core, and limited to 100 at a time on Scale. I've managed to delete the snapshots now after some faffing
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
