SMB Won't start-Reinstalled still cant get it
bryanpwatson
Any help is much appreciated, I have a FreeNas setup that has worked flawlessly for a couple years. I don't do nightlies only stable version upgrades. My system for the past week has not allowed SMB to start at all. I have tried reinstalling FreeNas completely with no luck. Also when I try to start SMB in shell it says:
samba_service does not exist in /etc/rc.d or the local startup
directories (/etc/ix/rc.d /usr/local/etc/rc.d), or is not executable
anodos
Sambassador
Try the following:
chmod -R 750 /var/db/samba4/
chmod -R 700 /var/db/samba4/private
then service samba_server restart
bryanpwatson
Try the following:
bryanpwatson
Send me the output of 'sh -x /usr/local/etc/rc.d/samba_server onerestart'
how can i get this info over its alot to print screen
bryanpwatson
saved as a PDF
  • FreenNAS.pdf
bryanpwatson
so just an update I can access this from a NFS share but unfortunately it doesnt play nicely with the use of the server
bryanpwatson
anyone there?
TrumanHW
I have the same issue as the OP here ... in which within:
root@freenas[/usr/local/etc/rc.d]# service samba_service start
samba_service does not exist in /etc/rc.d or the local startup directories (/etc/ix.rc.d /usr/local/etc/rc.d), or is not executable.
Since this seems common -- perhaps we could post the results here for others ... the issues are literally identical; no point concealing the solution.
Any help with this issue would be greatly appreciated.
And lets me get back to my OTHER FreeNAS tech. problems ... :smile:
Ha! And this community criticized my usage of NFS: "NFS sucks - you should use CIFS/SMB." Cost 10 hours trying to make a protocol not present work. :)
Two years in to using FreeNAS & have yet another hurdle before I can resume figuring out why I get 140MB/s - 250MB via 8x 10TB 7200rpm SAS via 10GbE
Before I got about 800MB/s with this array in about an hour -- with a dedicated RAID controller
Granted: networking nor Linux are my fortés. But it was minimal work before. HOPEFULLY, Hopefully upon solving this I get ~450MB/s .. (soon).
TrumanHW
PS - I've SSH'd in and ensured the permissions were set to 700 in:
IP > var > db > system > samba4 > private > msg.sock
.... however, if you have this problem and have yet to try that solution you may want to do so; perhaps easiest done via a GUI interface ...
anodos
Sambassador
It's samba_server, not samba_service.
TrumanHW
Ah - okay ... (didn't see the link when replying from my phone).
Thx
