peter boos
 - Sep 21, 2020
I have a single domain, in which another company is hosted as well.
So they login to the same domain, but at group membership level companies are separated.
On Freenas eNAS-11.3-U1
We have domain user Xerox7830 its member of compA and compB
Both companies use their own temp folder, to store scans. (\\compA\temp \\compB\temp
Users may not see the temp files of the other companie.
Users are member of compA or compB.
Only the xerox is member of both company groups.
The xerox does SMB connect over ip, and uses the same domain user (who is member of compA and compB).
Sofar i've been unable to set the permission so that both companies can use the printer.
I would assume that adding the group compA and compB to Xerox7830 user in (Samba) "Active Directory users and computers"
Then grant each group full permissions on their temp folders would work.
I also tried adding the user xerox7830 in the share permissions directly by name, but this user is unable to see both temp folders.
How should permissions look like for such config.
