johnhamelink
- Dec 16, 2022
Hi there,
I'm trying to move a ZFS pool I had in my desktop into a server I just bought (my first server - very exciting!). When I try to import the pool, the OpenZFS successfully mounts the pool to
The UI does not show the pool as having been imported, and subsequent import attempts will show no pools - that is until you run
/mnt/run/media/john/pool, but the TrueNAS UI fails with the following error:Code:
Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 973, in update_zfs_object_props zfs_object.update_properties(properties) File "libzfs.pyx", line 3388, in libzfs.ZFSResource.update_properties libzfs.ZFSException: SMB share creation failed During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 114, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1146, in nf res = f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1276, in nf return func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 947, in do_update self.update_zfs_object_props(properties, dataset) File "libzfs.pyx", line 411, in libzfs.ZFS.__exit__ File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 947, in do_update self.update_zfs_object_props(properties, dataset) File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 975, in update_zfs_object_props raise CallError(f'Failed to update properties: {e!r}') middlewared.service_exception.CallError: [EFAULT] Failed to update properties: ZFSException('SMB share creation failed') """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 411, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 446, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1140, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 1429, in import_pool await self.middleware.call('zfs.dataset.update', pool_name, opts) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1345, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1294, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/service.py", line 931, in update rv = await self.middleware._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1302, in _call return await self._call_worker(name, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1308, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1223, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) middlewared.service_exception.CallError: [EFAULT] Failed to update properties: ZFSException('SMB share creation failed')
CloseThe UI does not show the pool as having been imported, and subsequent import attempts will show no pools - that is until you run
zpool export from System Settings -> Shell.
