Sharkyparky
- Jun 7, 2020
Hey,
After I installed Centos 7 on a VM my SMB server magically died.
I've done some checks following:
www.truenas.com
www.truenas.com
Without any luck.
I tried to verify files which just resulted in an "All good" and even tried to look up if you can reinstall SMB.
Current Train: TrueNAS-12.0-STABLE - Release Train for TrueNAS 12.0 [release]
Hopefully, someone can help me.
Regard frightened TrueNAS user.
SMB service failed to start.
My hardware had a power disruption. Since then I get SMB service failed to start. Last time, I got the advise of running chmod 0750 /var/db/samba4/winbindd_privileged and it fixed the problem. This time I run it and get the error message: root@freenas[/]# chmod 777...
SMB service failed to start. HELP!
SMB will not start. Running 11.2 stable. SMB worked fine on my first install but I screwed up permissions so bad somehow Freenas wouldnt even start so I reinstalled and reimported my pool. I've reinstalled twice now with the same result. Vanilla install smb toggles on. I reimport my pool and...
