SMB access from Oppo media player
CPU: AMD Ryzen 5 5600X
MB: Gigabyte X570S AORUS PRO AX MB
RAM: 32GB of Kingston KSM32ED8/16HD 16GB (1x16GB) PC4-25600 (3200MHz) ECC Unbuffered DDR4
BOOT DRIVE: Samsung 1TB SSD, 980 PRO, M.2 2280 NVMe PCIe Gen4
DRIVES: 40TB of Western Digital WD 10TB Red Plus NAS 3.5" Hard Drive
TRUENAS SCALE 22.12
Hello everyone.
I am new to Truenas and I have been trying to give my Oppo media player access to my SMB share and I just can't get it to work.
I have created a user and in permissions given it access to the share. I can use this user from my windows machines and my android phone no problem, however when I use these details on the Oppo I get: Login Failed please verify username and password.
Attached are screenshots of the dataset and settings, SMB share settings and ACL settings.
Any and all help is greatly appreciated. Apologies if I have not provided enough information (and my lack of knowledge in Truenas).
Cheers.
anodos
Sambassador
Check output of midclt call smb.status AUTH_LOG | jq. This may give some indication about why it's failing. This may be one of those devices out there that is using legacy / insecure access methods.
So I put this into the shell, (which is what I am assuming you meant. (Apologies if mistaken.)
It seems to be the same thing repeated a about 20 times....This is the output.
"type": "Authentication",
"Authentication": {
"version": {
"major": 1,
"minor": 2
"eventId": 4625,
"logonId": "0",
"logonType": 3,
"status": "NT_STATUS_NO_SUCH_USER",
"localAddress": "ipv4:192.168.1.100:445",
"remoteAddress": "ipv4:192.168.1.22:65102",
"serviceDescription": "SMB2",
"authDescription": null,
"clientDomain": "MicrosoftAccount",
"clientAccount": "lukeaton@gmail.com",
"workstation": "NZXT",
"becameAccount": null,
"becameDomain": null,
"becameSid": null,
"mappedAccount": "lukeaton@gmail.com",
"mappedDomain": "MicrosoftAccount",
"netlogonComputer": null,
"netlogonTrustAccount": null,
"netlogonNegotiateFlags": "0x00000000",
"netlogonSecureChannelType": 0,
"netlogonTrustAccountSid": null,
"passwordType": "NTLMv2",
"duration": 1778
"timestamp_tval": {
"tv_sec": 1671688765,
"tv_usec": 673498
Sorry, I had to put into a text document as to fit it all into post.
  • Output.zip
Yes the ip is static which I enforced 192.168.1.86.
SMB1? No I haven't. Noob question. Where am I able to do that?
Nevermind I was able to find it. I enabled both SMB1 and NTLMv1 Auth and now my Oppo player connects fine.
I do understand enough to know that this isn't great for security though, correct?
Is there a way around this, or is it a matter of using a different device so that I don't have to enable SMB1?
Thank you for your help.
