Got a lovely email overnight corresponding to the following error in the messages log:
And a big red critical alert in the GUI.
But...zpool status has everything still online, and I'm not actually seeing this in smartctl?
Also nothing on any of the other drives. So where did this come from? Anything I should do to check in further detail?
EDIT:
FreeNAS-9.3-STABLE-201511040813
Intel E3-1220 v3
Asrock E3C224D2I
16GB ECC
4xSeagate 4TB ST4000DM000 and 2x WD Green 4TB Greens WD40EZRX in a RAIDZ2
Nov 18 00:34:46 freenas smartd[2845]: Device: /dev/ada0, 8 Currently unreadable (pending) sectors Nov 18 00:34:46 freenas smartd[2845]: Device: /dev/ada0, 8 Offline uncorrectable sectors Nov 18 00:34:46 freenas smartd[2845]: Device: /dev/ada0, 8 Currently unreadable (pending) sectors Nov 18 00:34:46 freenas smartd[2845]: Device: /dev/ada0, 8 Offline uncorrectable sectors
$ sudo smartctl -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
Model Family: Seagate Desktop HDD.15
Device Model: ST4000DM000-1F2168
Serial Number: S301BMGT
LU WWN Device Id: 5 000c50 0807c7b78
Firmware Version: CC54
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5900 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Nov 18 11:29:36 2015 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 107) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 525) minutes.
Conveyance self-test routine
SCT capabilities: (0x1085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 111 099 006 Pre-fail Always - 35086976
3 Spin_Up_Time 0x0003 091 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 24
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 068 060 030 Pre-fail Always - 6804147
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1035
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 24
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 064 058 045 Old_age Always - 36 (Min/Max 19/38)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 63
194 Temperature_Celsius 0x0022 036 042 000 Old_age Always - 36 (0 18 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1034h+49m+07.586s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1512806165
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 39894388448
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 1035 -
# 2 Short offline Completed without error 00% 761 -
# 3 Short offline Completed without error 00% 688 -
# 4 Short offline Completed without error 00% 520 -
# 5 Short offline Completed without error 00% 360 -
# 6 Short offline Completed without error 00% 135 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
EDIT:
Intel E3-1220 v3
Asrock E3C224D2I
16GB ECC
