ykhodo
- Oct 19, 2017
Is it time to replace my drive? How can I correct this error?
Here is the smartctl output:
and zpool status:
TIA
# smartctl -q noserial -a /dev/ada1
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Green
Device Model: WDC WD50EZRX-00MVLB1
Firmware Version: 80.00A80
User Capacity: 5,000,981,078,016 bytes [5.00 TB]
Rotation Rate: 5700 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Aug 7 21:08:30 2019 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (55080) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 551) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 210 196 021 Pre-fail Always - 8458
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 128
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 055 055 000 Old_age Always - 32909
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 128
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 86
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1116528
194 Temperature_Celsius 0x0022 118 112 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 4
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 4
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 4
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: read failure 90% 32843 2433515558
# 2 Short offline Completed: read failure 90% 32603 3164800184
# 3 Extended offline Completed: read failure 10% 32515 3164800184
# 4 Short offline Completed without error 00% 32435 -
# 5 Short offline Completed without error 00% 32267 -
# 6 Extended offline Completed without error 00% 32183 -
# 7 Short offline Completed without error 00% 32099 -
# 8 Short offline Completed without error 00% 31884 -
# 9 Extended offline Completed without error 00% 31800 -
#10 Short offline Completed without error 00% 31716 -
#11 Short offline Completed without error 00% 31548 -
#12 Extended offline Completed without error 00% 31464 -
#13 Short offline Completed without error 00% 31380 -
#14 Short offline Completed without error 00% 31141 -
#15 Extended offline Completed without error 00% 31056 -
#16 Short offline Completed without error 00% 30973 -
#17 Short offline Completed without error 00% 30805 -
#18 Extended offline Completed without error 00% 30721 -
#19 Short offline Completed without error 00% 30638 -
#20 Short offline Completed without error 00% 30422 -
#21 Extended offline Completed without error 00% 30337 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.and zpool status:
[root@hadrian ~]# zpool status
pool: aventador
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub repaired 0 in 0 days 00:01:47 with 0 errors on Fri Aug 2 04:01:53 2019
NAME STATE READ WRITE CKSUM
aventador ONLINE 0 0 0
gptid/aaeac8c7-ffd6-11e7-8518-7085c250805c.eli ONLINE 0 0 0
errors: No known data errors
pool: cicero
state: ONLINE
scan: scrub repaired 0 in 0 days 05:10:47 with 0 errors on Thu Aug 1 09:10:50 2019
cicero ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/d5d09b92-b46b-11e7-ae03-7085c250805c.eli ONLINE 0 0 0
gptid/d67a28b6-b46b-11e7-ae03-7085c250805c.eli ONLINE 0 0 0
gptid/d73c5c19-b46b-11e7-ae03-7085c250805c.eli ONLINE 0 0 0
gptid/d7fd0a56-b46b-11e7-ae03-7085c250805c.eli ONLINE 0 0 0
gptid/d8c2f01d-b46b-11e7-ae03-7085c250805c.eli ONLINE 0 0 0
gptid/d9873e17-b46b-11e7-ae03-7085c250805c.eli ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:01:28 with 0 errors on Sat Aug 3 03:46:28 2019
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errorsTIA
