smartctl failed (was interrupted) due to a planned reboot, how to clear the 'unhealthy' flag on the affected pools
Hi I got the similar problem, pool gave me a warning, zpool status shows check sum error. Was clear after a scrub. But before the scrub I ran a long SMART test and was aborted. Now the smart history always show the aborted test, anyway to clear that? Is the smart history stored in HDD or the OS?
Stored in the HDD. It cannot be cleared. HDD's internal firmware keeps a log of the 21 most recent SMART selftest results.
So I just need to run short test 22 time and it will clear?? :)
Or just ignore the aborted test. :tongue: Cover your screen with duct tape if it helps.
