Hi. I was doing drive validation using the SMART tests (from Uncle Festers Guide) and I got some curious results that maybe you can help me with.
The drives are Seagate 5.0TB ST5000DM000-1FK178 (Yeah, I know cheap ones.) The complete results from the extended test are at the bottom, but the numbers I'm curious about are Item #1 & #195, they show. . .
So, is this drive bad or is it okay because hardware ECC corrected the read errors? The test says no errors logged. If I call Seagate Tech Support you know they are going to say the drive is fine :)
Thanks in advance for any info you have to offer,
Megan Quattrocchi
1 Raw_Read_Error_Rate 0x000f 114 100 006 Pre-fail Always - 60130752 195 Hardware_ECC_Recovered 0x001a 114 100 000 Old_age Always - 60130752
Megan Quattrocchi
3 Spin_Up_Time 0x0003 092 091 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 23
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 20688986
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 85
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 23
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 071 063 045 Old_age Always - 29 (Min/Max 28/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 25
194 Temperature_Celsius 0x0022 029 040 000 Old_age Always - 29 (0 22 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 85h+02m+02.549s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 9769454997
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 5110591723
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 74 -
# 2 Extended offline Completed without error 00% 48 -
# 3 Conveyance offline Completed without error 00% 38 -
# 4 Short offline Completed without error 00% 38 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay
