Hi there,
I just installed my first TrueNAS server and so far enjoying it. I have eight 6TB drives in a Dell R730 server. I am seeing the following SMART errors. Are they anything I should be concerned about?
---- snip ----
Dec 19 04:37:06 truenas 1 2021-12-19T04:37:06.271821-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 33 to 34
Dec 19 05:07:05 truenas 1 2021-12-19T05:07:05.424201-08:00 <hostname> smartd 3128 - - Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 157 to 161
Dec 19 05:07:05 truenas 1 2021-12-19T05:07:05.633458-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 83 to 84
Dec 19 05:07:05 truenas 1 2021-12-19T05:07:05.633485-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 66 to 67
Dec 19 05:07:05 truenas 1 2021-12-19T05:07:05.633496-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 34 to 33
Dec 19 05:07:05 truenas 1 2021-12-19T05:07:05.633505-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 83 to 84
Dec 19 05:37:05 truenas 1 2021-12-19T05:37:05.736525-08:00 <hostname> smartd 3128 - - Device: /dev/da7 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 157 to 152
Dec 19 05:37:05 truenas 1 2021-12-19T05:37:05.757325-08:00 <hostname> smartd 3128 - - Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 161 to 157
Dec 19 05:37:05 truenas 1 2021-12-19T05:37:05.827417-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 84 to 100
Dec 19 05:37:05 truenas 1 2021-12-19T05:37:05.827435-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 84 to 100
Dec 19 05:37:05 truenas 1 2021-12-19T05:37:05.986669-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 67 to 66
Dec 19 05:37:05 truenas 1 2021-12-19T05:37:05.986686-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 33 to 34
Dec 19 06:07:05 truenas 1 2021-12-19T06:07:05.467807-08:00 <hostname> smartd 3128 - - Device: /dev/da7 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 152 to 157
Dec 19 06:07:05 truenas 1 2021-12-19T06:07:05.549140-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 100 to 68
Dec 19 06:07:05 truenas 1 2021-12-19T06:07:05.549160-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 100 to 68
Dec 19 06:07:05 truenas 1 2021-12-19T06:07:05.689926-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 66 to 67
Dec 19 06:07:05 truenas 1 2021-12-19T06:07:05.689942-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 34 to 33
Dec 19 06:37:05 truenas 1 2021-12-19T06:37:05.895707-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 68 to 70
Dec 19 06:37:05 truenas 1 2021-12-19T06:37:05.895759-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 68 to 70
Dec 19 07:07:05 truenas 1 2021-12-19T07:07:05.608973-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 70 to 72
Dec 19 07:07:05 truenas 1 2021-12-19T07:07:05.609004-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 70 to 72
Dec 19 07:07:05 truenas 1 2021-12-19T07:07:05.746330-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 84 to 100
Dec 19 07:07:05 truenas 1 2021-12-19T07:07:05.746353-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 84 to 100
Dec 19 07:37:05 truenas 1 2021-12-19T07:37:05.869117-08:00 <hostname> smartd 3128 - - Device: /dev/da5 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 148 to 152
Dec 19 07:37:05 truenas 1 2021-12-19T07:37:05.876138-08:00 <hostname> smartd 3128 - - Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 157 to 161
Dec 19 07:37:05 truenas 1 2021-12-19T07:37:05.890252-08:00 <hostname> smartd 3128 - - Device: /dev/da2 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 157 to 161
Dec 19 07:37:05 truenas 1 2021-12-19T07:37:05.947123-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 72 to 73
Dec 19 07:37:05 truenas 1 2021-12-19T07:37:05.947140-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 72 to 73
Dec 19 08:07:05 truenas 1 2021-12-19T08:07:05.385408-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 64 to 65
Dec 19 08:07:05 truenas 1 2021-12-19T08:07:05.385438-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 36 to 35
Dec 19 08:37:05 truenas 1 2021-12-19T08:37:05.687157-08:00 <hostname> smartd 3128 - - Device: /dev/da5 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 152 to 148
Dec 19 08:37:05 truenas 1 2021-12-19T08:37:05.694169-08:00 <hostname> smartd 3128 - - Device: /dev/da4 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 161 to 157
Dec 19 08:37:05 truenas 1 2021-12-19T08:37:05.708163-08:00 <hostname> smartd 3128 - - Device: /dev/da2 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 161 to 157
Dec 19 08:37:05 truenas 1 2021-12-19T08:37:05.765092-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 65 to 64
Dec 19 08:37:05 truenas 1 2021-12-19T08:37:05.765108-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 35 to 36
Dec 19 09:07:06 truenas 1 2021-12-19T09:07:06.267088-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Prefailure Attribute: 7 Seek_Error_Rate changed from 77 to 78
Dec 19 09:07:06 truenas 1 2021-12-19T09:07:06.267120-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 67 to 66
Dec 19 09:07:06 truenas 1 2021-12-19T09:07:06.267134-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 33 to 34
Dec 19 10:07:06 truenas 1 2021-12-19T10:07:06.023388-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 66 to 67
Dec 19 10:07:06 truenas 1 2021-12-19T10:07:06.023421-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 34 to 33
Dec 19 10:37:05 truenas 1 2021-12-19T10:37:05.246548-08:00 <hostname> smartd 3128 - - Device: /dev/da3 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 152 to 148
Dec 19 11:07:06 truenas 1 2021-12-19T11:07:06.154361-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 100 to 64
Dec 19 11:07:06 truenas 1 2021-12-19T11:07:06.154392-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 67 to 66
Dec 19 11:07:06 truenas 1 2021-12-19T11:07:06.154404-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 194 Temperature_Celsius changed from 33 to 34
Dec 19 11:07:06 truenas 1 2021-12-19T11:07:06.154415-08:00 <hostname> smartd 3128 - - Device: /dev/da0 [SAT], SMART Usage Attribute: 195 Hardware_ECC_Recovered changed from 100 to 64
Dec 19 11:37:05 truenas 1 2021-12-19T11:37:05.735532-08:00 <hostname> smartd 3128 - - Device: /dev/da1 [SAT], SMART Prefailure Attribute: 7 Seek_Error_Rate changed from 77 to 78
---- snip ----
---- snip ----
---- snip ----
