Well guess what folks - I ran into the same situation. Found an incredibly good deal on Ebay that was far too good to pass up and scooped up the exact same model TD350 w/ the AnyRaid 720ix controller. After finally modding the fans with Noctua's and making the necessary firmware updates, I finally got to unpacking my shiny new Lenovo 530-8i aka LSI 9400-8i only to find to my horror and to some of you following this thread that there's quite frankly nowhere to plug into. After getting over my horror, I panickly called Lenovo's support (the machine still had warranty) only to spend an hour and half to get to the same conclusion I had initially. The 15 drive variety of this monster can indeed ONLY support the 720ix.
Not quite sure what to do with this now - this can't replace the T420 I was intending to replace.
Also - the 05:00.0 PCI bridge: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge (rev 03) device is simply part of the onboard BMC/VGA adapter
ses0: <Lenovo 720ix 0305> Fixed Enclosure Services SPC-3 SCSI device
ses0: 150.000MB/s transferscd0: <PLDS DVDROM DH16D8SH ML31> Removable CD-ROM SCSI device
ses0: SES Device
cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed
ses0: (none) in 'ArrayDevice00', SAS Slot: 1 phys at slot 0
ses0: phy 0: SAS device type 1 phy 0 Target ( SSP )
ses1 at ahciem0 bus 0 scbus7 target 0 lun 0
run_interrupt_driven_hooks: still waiting after 180 seconds forses0: phy 0: parent 500062b2017bdb7f addr 5000c5009457eef5
xpt_config enc_nop_confighook_cbses1: enc_nop_confighook_cb
<AHCI SGPIO Enclosure 2.00 0001> SEMB S-E-S 2.00 device
ses1: SEMB SES Device
ses2 at ahciem1 bus 0 scbus14 target 0 lun 0
ses1: cd0 in 'Slot 03', SATA Slot: scbus6 target 0
ses2: <AHCI SGPIO Enclosure 2.00 0001> SEMB S-E-S 2.00 device
ses2: SEMB SES Device
ses0: (none) in 'ArrayDevice01', SAS Slot: 1 phys at slot 1
da0 at mrsas0 bus 1 scbus2 target 30 lun 0
da1 at mrsas0 bus 1 scbus2 target 31 lun 0
da2 at mrsas0 bus 1 scbus2 target 32 lun 0
da3 at mrsas0 bus 1 scbus2 target 33 lun 0
da2: da0: da3: da1: <LENOVO ST1200MM0088 L58C> Fixed Direct Access SPC-4 SCSI device
ses0: phy 0: parent 500062b2017bdb7f addr 5000c500945881cd
da0: Serial Number Z4020JSX0000C7528B46
da2: Serial Number Z4020K6W0000C7528GRD
da3: Serial Number Z4020GX20000C8014GRC
da0: 150.000MB/s transfersda2: 150.000MB/s transfersda3: 150.000MB/s transfers
da1: Serial Number Z4020BGF0000C7525SET
da2: 1144641MB (2344225968 512 byte sectors)
da0: 1144641MB (2344225968 512 byte sectors)
da1: 150.000MB/s transfersda5 at umass-sim0 bus 0 scbus16 target 0 lun 0
da3: 1144641MB (2344225968 512 byte sectors)
da5:
da1: 1144641MB (2344225968 512 byte sectors)
<SanDisk Cruzer Fit 1.00> Removable Direct Access SPC-4 SCSI device
da4 at mrsas0 bus 1 scbus2 target 34 lun 0
da4: da5: Serial Number 4C530001160108116224
da5: 40.000MB/s transfers<LENOVO ST1200MM0088 L58C> Fixed Direct Access SPC-4 SCSI device
da5: 30528MB (62521344 512 byte sectors)
da5: quirks=0x2<NO_6_BYTE>
da4: Serial Number Z4020FX20000C801BQ7V
da4: 150.000MB/s transfers
da4: 1144641MB (2344225968 512 byte sectors)
ses0: da0,pass1 in 'ArrayDevice02', SAS Slot: 1 phys at slot 2
ses0: phy 0: parent 500062b2017bdb7f addr 5000c50094587905
ses0: da3,pass4 in 'ArrayDevice03', SAS Slot: 1 phys at slot 3
ses0: phy 0: parent 500062b2017bdb7f addr 5000c500945901e5
ses0: da4,pass5 in 'ArrayDevice04', SAS Slot: 1 phys at slot 4
ses0: phy 0: parent 500062b2017bdb7f addr 5000c50094592ee5
root@freenas[~]# storcli /c0 show all
Generating detailed summary of the adapter, it may take a while to complete.
CLI Version = 007.1207.0000.0000 Sep 25, 2019
Operating system = FreeBSD 11.3-RELEASE-p7
Controller = 0
Status = Success
Description = None
Basics :
Controller = 0
Model = Lenovo ThinkServer RAID 720ix AnyRAID Adapter
Serial Number = SV62842083
Current Controller Date/Time = 05/01/2020, 05:28:07
Current System Date/time = 04/30/2020, 22:28:06
SAS Address = 500062b2017bdb70
PCI Address = 00:03:00:00
Mfg Date = 07/11/16
Rework Date = 00/00/00
Revision No = 07C
Version :
Firmware Package Build = 24.21.0-0124
Firmware Version = 4.680.00-8515
CPLD Version = 26971-00A
Bios Version = 6.36.00.3_4.19.08.00_0x06180203
HII Version = 03.25.05.12
NVDATA Version = 3.1705.00-0020
Ctrl-R Version = 5.19-0603
Preboot CLI Version = 01.07-05:#%0000
Boot Block Version = 3.07.00.00-0003
Driver Name = mrsas
Driver Version = 07.709.04.00-fbsd
Bus :
Vendor Id = 0x1000
Device Id = 0x5D
SubVendor Id = 0x17AA
SubDevice Id = 0x1053
Host Interface = PCI-E
Device Interface = SAS-12G
Bus Number = 3
Device Number = 0
Function Number = 0
Pending Images in Flash :
Image name = No pending images
Status :
Controller Status = Optimal
Memory Correctable Errors = 0
Memory Uncorrectable Errors = 0
ECC Bucket Count = 0
Any Offline VD Cache Preserved = No
BBU Status = NA
PD Firmware Download in progress = No
Support PD Firmware Download = No
Lock Key Assigned = No
Failed to get lock key on bootup = No
Lock key has not been backed up = No
Bios was not detected during boot = No
Controller must be rebooted to complete security operation = No
A rollback operation is in progress = No
At least one PFK exists in NVRAM = Yes
SSC Policy is WB = No
Controller has booted into safe mode = No
Controller shutdown required = No
Supported Adapter Operations :
Rebuild Rate = Yes
CC Rate = Yes
BGI Rate = Yes
Reconstruct Rate = Yes
Patrol Read Rate = Yes
Alarm Control = No
Cluster Support = No
BBU = NA
Spanning = Yes
Dedicated Hot Spare = Yes
Revertible Hot Spares = Yes
Foreign Config Import = Yes
Self Diagnostic = Yes
Allow Mixed Redundancy on Array = No
Global Hot Spares = Yes
Deny SCSI Passthrough = No
Deny SMP Passthrough = No
Deny STP Passthrough = No
Support more than 8 Phys = Yes
FW and Event Time in GMT = No
Support Enhanced Foreign Import = Yes
Support Enclosure Enumeration = Yes
Support Allowed Operations = Yes
Abort CC on Error = Yes
Support Multipath = Yes
Support Odd & Even Drive count in RAID1E = No
Support Security = Yes
Support Config Page Model = Yes
Support the OCE without adding drives = Yes
Support EKM = Yes
Snapshot Enabled = No
Support PFK = Yes
Support PI = Yes
Support LDPI Type1 = No
Support LDPI Type2 = No
Support LDPI Type3 = No
Support Ld BBM Info = No
Support Shield State = Yes
Block SSD Write Disk Cache Change = Yes
Support Suspend Resume BG ops = Yes
Support Emergency Spares = Yes
Support Set Link Speed = Yes
Support Boot Time PFK Change = No
Support JBOD = Yes
Disable Online PFK Change = No
Support Perf Tuning = Yes
Support SSD PatrolRead = Yes
Real Time Scheduler = Yes
Support Reset Now = Yes
Support Emulated Drives = Yes
Headless Mode = Yes
Dedicated HotSpares Limited = No
Point In Time Progress = Yes
Extended LD = Yes
Support Uneven span = No
Support Config Auto Balance = No
Support Maintenance Mode = No
Support Diagnostic results = Yes
Support Ext Enclosure = Yes
Support Sesmonitoring = Yes
Support SecurityonJBOD = Yes
Support ForceFlash = Yes
Support DisableImmediateIO = Yes
Support LargeIOSupport = Yes
Support DrvActivityLEDSetting = Yes
Support FlushWriteVerify = Yes
Support CPLDUpdate = Yes
Support ForceTo512e = Yes
Support discardCacheDuringLDDelete = Yes
Support JBOD Write cache = No
Support Large QD Support = No
Support Ctrl Info Extended = No
Support IButton less = No
Support AES Encryption Algorithm = No
Support Encrypted MFC = No
Support Snapdump = Yes
Support Force Personality Change = No
Support Dual Fw Image = No
Support PSOC Update = No
Support Secure Boot = No
Support Debug Queue = Yes
Support Least Latency Mode = Yes
Support OnDemand Snapdump = Yes
Support Clear Snapdump = Yes
Support FW Triggered Snapdump = Yes
Support PHY current speed = No
Support Lane current speed = No
Support NVMe Width = No
Support Lane DeviceType = No
Enterprise Key management :
Capability = Supported
Boot Agent = Not Available
Configured = No
Supported PD Operations :
Force Online = Yes
Force Offline = Yes
Force Rebuild = Yes
Deny Force Failed = No
Deny Force Good/Bad = No
Deny Missing Replace = No
Deny Clear = No
Deny Locate = No
Support Power State = Yes
Set Power State For Cfg = No
Support T10 Power State = No
Support Temperature = Yes
NCQ = Yes
Support Max Rate SATA = No
Support Degraded Media = No
Support Parallel FW Update = Yes
Support Drive Crypto Erase = Yes
Support SSD Wear Gauge = No
Supported VD Operations :
Read Policy = Yes
Write Policy = Yes
IO Policy = Yes
Access Policy = Yes
Disk Cache Policy = Yes
Reconstruction = Yes
Deny Locate = No
Deny CC = No
Allow Ctrl Encryption = No
Enable LDBBM = Yes
Support FastPath = Yes
Performance Metrics = Yes
Power Savings = No
Support Powersave Max With Cache = No
Support Breakmirror = Yes
Support SSC WriteBack = No
Support SSC Association = No
Support VD Hide = Yes
Support VD Cachebypass = Yes
Support VD discardCacheDuringLDDelete = Yes
Support VD Scsi Unmap = No
Advanced Software Option :
Adv S/W Opt Time Remaining Mode
MegaRAID FastPath Unlimited Secured
MegaRAID SafeStore Unlimited Secured
MegaRAID RAID6 Unlimited Secured
MegaRAID RAID5 Unlimited Secured
Safe ID = X1EQDHF96IUW32CDV655KTVTGGNP1X9DH8T5C3RZ
HwCfg :
ChipRevision = C0
BatteryFRU = N/A
Front End Port Count = 0
Backend Port Count = 8
BBU = Absent
Alarm = Missing
Serial Debugger = Present
NVRAM Size = 32KB
Flash Size = 32MB
On Board Memory Size = 1024MB
CacheVault Flash Size = NA
TPM = Absent
Upgrade Key = Present
On Board Expander = Present
Temperature Sensor for ROC = Present
Temperature Sensor for Controller = Absent
Upgradable CPLD = Present
Upgradable PSOC = Absent
Current Size of CacheCade (GB) = 0
Current Size of FW Cache (MB) = 907
ROC temperature(Degree Celsius) = 89
Policies :
Policies Table :
Policy Current Default
Predictive Fail Poll Interval 300 sec
Interrupt Throttle Active Count 16
Interrupt Throttle Completion 50 us
Rebuild Rate 30 % 30%
PR Rate 30 % 30%
BGI Rate 30 % 30%
Check Consistency Rate 30 % 30%
Reconstruction Rate 30 % 30%
Cache Flush Interval 4s
Flush Time(Default) = 4s
Drive Coercion Mode = 128MB
Auto Rebuild = On
Battery Warning = On
ECC Bucket Size = 15
ECC Bucket Leak Rate (hrs) = 24
Restore Hot Spare on Insertion = On
Expose Enclosure Devices = On
Maintain PD Fail History = On
Reorder Host Requests = On
Auto detect BackPlane = SGPIO/i2c SEP
Load Balance Mode = Auto
Security Key Assigned = Off
Disable Online Controller Reset = Off
Use drive activity for locate = Off
Boot :
BIOS Enumerate VDs = 1
Stop BIOS on Error = Off
Delay during POST = 0
Spin Down Mode = None
Enable Ctrl-R = No
Enable Web BIOS = No
Enable PreBoot CLI = No
Enable BIOS = Yes
Max Drives to Spinup at One Time = 2
Maximum number of direct attached drives to spin up in 1 min = 10
Delay Among Spinup Groups (sec) = 12
Allow Boot with Preserved Cache = Off
High Availability :
Topology Type = None
Cluster Permitted = No
Cluster Active = No
Defaults :
Phy Polarity = 0
Phy PolaritySplit = 0
Strip Size = 256 KB
Write Policy = WT
Read Policy = No Read Ahead
Cache When BBU Bad = Off
Cached IO = Off
VD PowerSave Policy = Controller Defined
Default spin down time (mins) = 30
Coercion Mode = 128 MB
ZCR Config = Unknown
Max Chained Enclosures = 16
Direct PD Mapping = No
Restore Hot Spare on Insertion = Yes
Expose Enclosure Devices = Yes
Maintain PD Fail History = Yes
Zero Based Enclosure Enumeration = Yes
Disable Puncturing = Yes
EnableLDBBM = Yes
DisableHII = No
Un-Certified Hard Disk Drives = Allow
SMART Mode = Mode 6
Enable LED Header = Yes
LED Show Drive Activity = Yes
Dirty LED Shows Drive Activity = No
EnableCrashDump = Yes
Disable Online Controller Reset = No
Treat Single span R1E as R10 = No
Power Saving option = Disabled
TTY Log In Flash = Yes
Auto Enhanced Import = Yes
BreakMirror RAID Support = single span R1
Disable Join Mirror = Yes
Enable Shield State = Yes
Time taken to detect CME = 60 sec
Capabilities :
Supported Drives = SAS, SATA
RAID Level Supported = RAID0, RAID1(2 or more drives), RAID5, RAID6, RAID00, RAID10(2 or more drives per span), RAID50, RAID60
Enable JBOD = Yes
Mix in Enclosure = Allowed
Mix of SAS/SATA of HDD type in VD = Not Allowed
Mix of SAS/SATA of SSD type in VD = Not Allowed
Mix of SSD/HDD in VD = Not Allowed
SAS Disable = No
Max Arms Per VD = 32
Max Spans Per VD = 8
Max Arrays = 128
Max VD per array = 64
Max Number of VDs = 64
Max Parallel Commands = 928
Max SGE Count = 60
Max Data Transfer Size = 512 sectors
Max Strips PerIO = 128
Max Configurable CacheCade Size(GB) = 0
Max Transportable DGs = 0
Enable Snapdump = Yes
Enable SCSI Unmap = Yes
FDE Drive Mix Support = No
Min Strip Size = 64 KB
Max Strip Size = 1.000 MB
Scheduled Tasks :
Consistency Check Reoccurrence = 168 hrs
Next Consistency check launch = 05/02/2020, 03:00:00
Patrol Read Reoccurrence = 168 hrs
Next Patrol Read launch = 05/02/2020, 03:00:00
Battery learn Reoccurrence = NA
Next Battery Learn = NA
OEMID = Broadcom
JBOD Drives = 5
JBOD LIST :
EID:Slt DID State DG Size Intf Med SED PI SeSz Model Sp Type
0:0 31 JBOD - 1.090 TB SAS HDD N N 512B ST1200MM0088 U -
0:1 32 JBOD - 1.090 TB SAS HDD N N 512B ST1200MM0088 U -
0:2 30 JBOD - 1.090 TB SAS HDD N N 512B ST1200MM0088 U -
0:3 33 JBOD - 1.090 TB SAS HDD N N 512B ST1200MM0088 U -
0:4 34 JBOD - 1.090 TB SAS HDD N N 512B ST1200MM0088 U -
EID=Enclosure Device ID|Slt=Slot No.|DID=Device ID|Onln=Online|
Offln=Offline|Intf=Interface|Med=Media Type|SeSz=Sector Size
Physical Drives = 5
PD LIST :
EID=Enclosure Device ID|Slt=Slot No.|DID=Device ID|DG=DriveGroup
DHS=Dedicated Hot Spare|UGood=Unconfigured Good|GHS=Global Hotspare
UBad=Unconfigured Bad|Onln=Online|Offln=Offline|Intf=Interface
Med=Media Type|SED=Self Encryptive Drive|PI=Protection Info
SeSz=Sector Size|Sp=Spun|U=Up|D=Down|T=Transition|F=Foreign
UGUnsp=UGood Unsupported|UGShld=UnConfigured shielded|HSPShld=Hotspare shielded
CFShld=Configured shielded|Cpybck=CopyBack|CBShld=Copyback Shielded
UBUnsp=UBad Unsupported|Rbld=Rebuild
Enclosures = 2
Enclosure LIST :
EID State Slots PD PS Fans TSs Alms SIM Port# ProdID VendorSpecific
0 OK 28 5 0 0 1 0 0 Port 0 - 3 & Port 4 - 7 x8 720ix x48-125.3.5.1
252 OK 8 0 0 0 0 0 1 - SGPIO
EID=Enclosure Device ID |PD=Physical drive count |PS=Power Supply count|
TSs=Temperature sensor count |Alms=Alarm count |SIM=SIM Count
Edit: Updated to the latest enclosure firmware version - no change (125.3.9.0)
