I've gotten smart error on my FreeNAS GUI and the message says like "Device: /dev/ada1, new Self-Test Log error at hour timestamp 30426". Now, I tried to check with
Also, I did with
However, I don't see any errors on zpool volumes as below.
It would be time to replace the disk? Or It would be better to check with some commands?
Regards,
smartctl -a /dev/ada1 and the result was as below.Code:
SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 10% 30641 725477048 # 2 Extended offline Completed: read failure 10% 30631 723833392 # 3 Extended offline Completed: read failure 10% 30624 725440032 # 4 Extended offline Completed: read failure 10% 30615 722229056 # 5 Extended offline Completed: read failure 10% 30608 725440032 # 6 Extended offline Completed: read failure 10% 30600 728743176 # 7 Extended offline Completed: read failure 10% 30593 728604616 # 8 Extended offline Completed: read failure 10% 30586 728604616 # 9 Extended offline Completed: read failure 10% 30579 728604616 #10 Extended offline Completed: read failure 10% 30572 749791144 #11 Extended offline Completed: read failure 10% 30565 749787000 #12 Extended offline Completed: read failure 10% 30558 730245920 #13 Extended offline Completed: read failure 10% 30551 751350896 #14 Extended offline Completed: read failure 10% 30544 728604616 #15 Extended offline Completed: read failure 10% 30537 728604616 #16 Extended offline Completed: read failure 10% 30530 749787000 #17 Extended offline Completed: read failure 10% 30523 749791144 #18 Extended offline Completed: read failure 10% 30517 749585408 #19 Extended offline Completed: read failure 10% 30509 730335544 #20 Extended offline Completed: read failure 10% 30502 730404768 #21 Extended offline Completed: read failure 10% 30495 728723248
Also, I did with
smartctl -A /dev/ada1 and the output was as follows.Code:
=== START OF READ SMART DATA SECTION === SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1474 3 Spin_Up_Time 0x0027 180 175 021 Pre-fail Always - 5975 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 87 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 059 059 000 Old_age Always - 30651 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 86 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 46 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 263 194 Temperature_Celsius 0x0022 110 104 000 Old_age Always - 40 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 197 190 000 Old_age Offline - 1350 ---------------------------------------------------------------------------------------------------------------------------------------
root@jptyonas01:~ # zpool status pool: Data state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(7) for details. scan: scrub repaired 0 in 0 days 04:49:34 with 0 errors on Sun Aug 12 04:49:35 2018 config: NAME STATE READ WRITE CKSUM Data ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/3962f51c-57bf-11e5-8a07-bc5ff408d6e2 ONLINE 0 0 0 gptid/39d0a820-57bf-11e5-8a07-bc5ff408d6e2 ONLINE 0 0 0 gptid/3a420526-57bf-11e5-8a07-bc5ff408d6e2 ONLINE 0 0 0 gptid/3ab037bb-57bf-11e5-8a07-bc5ff408d6e2 ONLINE 0 0 0 gptid/3b2154e2-57bf-11e5-8a07-bc5ff408d6e2 ONLINE 0 0 0 errors: No known data errors
Regards,
