Hi guys,
I've been running the FreeNAS server for about a year now and have been unable to use it for the last few months because of a bug that has been solved a while ago. So I'm happy I can continue using FreeNAS again, but I still have some trouble getting good performance.
Some background information (jump to the * to skip),
I've got a 1 Gbps home network on which I mainly use a Macbook Pro, a few linux devices (RPI, home automation stuff, media player) and occasionally a Windows Laptop. Most devices were connected through wired ethernet and I was using Samba shares to access my drives. Read and write speeds were asome as it could easily saturate 1Gbps ethernet with both read and write tests.
I did have a lot of problems accessing the drives on my macbook, so after some time I switched to using NFS and that helped tremendously. Unfortunately there was a bug in 9.2 that screwed with permissions. A few months passed, my macbook died and I bought a new one, which.....had no ethernet connector. My Macbook is the device I use the most.
Last week I decided to upgrade to 9.10.2, which solved the permissions problem and I'm now again able to write to my shares.
Doing some tests I found that I could read and write with about 13MB/s (100Mbps) over my 802.11ac WiFi connection. I was hoping for a bit higher speed, so I created a FTP share and tried uploading a large file through FTP. It could upload the file at speeds over 35MBps, which is great.
I downloaded Helios Lantest and found that NFS and CIFS are in the same ballpark regarding performance, but WebDAV for example is much faster. For FTP I could not run the LanTest, but the large file copy also showed much higher speeds (>35MBps on Wifi 802.11ac) than using NFS. I know Wifi is not ideal, but speeds of over 25MBps (200Mbps I find acceptable for my home network).
Some numbers from LanTest,
NFS test
Create 300 files of 20 kB - 17,5s
Open/Close 300 files - 395ms
Remove 300 files - 3,8s
Write 300MB to file - 12,8MB/s
Read 300MB from file - 12,9MB/s
Lock/Unlock 16000 times - 59,7s
Read directory (640 files) - 14,2s
WebDAV test
Create 300 files of 20 kB - 8,9s
Open/Close 300 files - 26,3ms
Remove 300 files - 3,6s
Write 300MB to file - 39,9MB/s
Read 300MB from file - 5540,4 MB/s (An absurd number, is there some caching done maybe?)
Lock/Unlock 16000 times - N/A
Read directory (640 files) - 282,1ms
Do you have any ideas as to why this is or where I should start looking? Any help is appreciated!
[Edit: removed redundant images]
NFS test
WebDAV test
