What's the NIC driver (from ifconfig)? Anything related in /var/log/messages when the slowdown occurs?
The primary nic is:
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether 74:d4:35:1a:4c:5e
inet 192.168.3.116 netmask 0xffffff00 broadcast 192.168.3.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
I did not see any sort of re-occuring error or entry referencing re0 in /var/log/messages.
1. you should never let your drives spin down. it will cause premature failure from the added wear and tear.
2. full hardware specs, network layout, client specs and how are you measuring your performance? How did you decide it was "slow to respond"? Are you sure that isn't just normal? Iperf is a great way to test your network bandwidth.
My understanding is not all commercial drives will let you disable spindown. There is a mixture of hitachi, and some seagates I didn't want but the manufacture of the external drives I cracked open changed the drive they were using internally..I was expecting western digitals. I don't have spindown enabled in freenas, the drives are doing it themselves.
I measure slowdown as it taking 30+ seconds to load a local webpage on emby, sickrage or couchpotato on a consistant basis and not just when the drives are spinning up. I assumed the cpu might be maxed till I review usage in the freenas gui and saw almost none of the cpu was in use. I then assumed memory might be low given the amount of jails I had running but 32GB is the max memory that motherboard will take.
My server specs are:
Codegen Server 9011-C10 ATX case with power supply. [
http://www.pc-experience.de/wbb2/thread.php?threadid=18342 ]
GIGABYTE GA-Z87-DS3H LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
LGA3220T cpu
Ballistix Tactical 16GB Kit 8GBx2 DDR3 1600 MT/s PC3-12800 CL8 at 1.5V UDIMM 240-Pin Memory BLT2KIT8G3D1608DT1TX0
G.Skill F3-1600C9D-16GAR Ares 16GB (2x8GB) DDR3-1600Mhz Memory RAM
SYBA SI-PEX40064 PCI-Express 2.0 Low Profile Ready SATA III (6.0 Gb/s) Controller Card
SYBA SI-PEX40094 PCI Express Low Profile Ready SATA SATA III 2 Internal 6Gbps Ports PCI-e Controller Card
4 x Seagate ST5000DM000-1FK178 (5TB)
2 x TOSHIBA MD04ACA500 (5TB)
16 GB Flashdrive
1 x iStarUSA BPN-DE110SS-BLUE Trayless 5.25" to 3.5" SATA SAS 6 Gbps HDD Hot-swap Rack
2 x iStarUSA BPN-DE340SS-BLACK 3 x 5.25" to 4 x 3.5" SAS / SATA 6 .0 Gb/s Trayless Hot-Swap Cage - Black Handle - OEM
LSPCI shows:
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06)
00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller
#1 (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Se ries/C22 0 Series Chipset Family PCI Express Root Port
#1 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d5)
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port
#5 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI
#1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Z87 Express LPC Controller (rev 05)
00 :1f.2 SA TA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
03:00.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 41)
05:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11)
