Single drive Pool Offline after using replace drive option
man-u-l
I had a single 4Tb drive that was just starting to give me read errors so I got a new 5Tb drive for a Pool that uses only 1 drive (This is for Time Machine Mac backups so I dont need more than 1 drive)
I used the replace drive option from the dashboard, it took a while for truenas to resilver the pool, after the process was done I removed the old drive but the pool is now offline and I cannot import it, I tried a few things I read here but no luck, at this point I dont care about the data, all I will like to do is to add the new 5Tb disk to that existing pool and continue to make my TimeMachine backups, I know I can just create a new Pool but the existing one already has the permissions and storage limits for the 2 Macs I backup to.
Thanks in advanced!
Davvo
You likely removed the wrong drive.
Output of zpool status and camcontrol devlist please, using [CODE][/CODE] tags.
man-u-l
Thanks, 100% sure the correct drive was removed as that was 4Tb and my other pool is configured with 6Tb drives and I have no problems with the other pool.
RESULT IN SYSTEM FAILURE.
root@TrueNas[~]# zpool status
  pool: NAS state: ONLINE
  scan: scrub repaired 0B in 03:44:24 with 0 errors on Sun Oct 22 03:44:24 2023
        NAS                                             ONLINE       0     0 0
          raidz2-0                                      ONLINE       0     0 0
            gptid/ac8f9b21-ae1f-11ed-ba90-ac1f6b61c610  ONLINE       0     0 0
            gptid/ac979464-ae1f-11ed-ba90-ac1f6b61c610  ONLINE       0     0 0
root@TrueNas[~]# zpool status  pool: NAS
 state: ONLINE  scan: scrub repaired 0B in 03:44:24 with 0 errors on Sun Oct 22 03:44:24 2023
        NAME                                            STATE     READ WRITE CKS
UM
        NAS                                             ONLINE       0     0
 0
          raidz2-0                                      ONLINE       0     0
 0
 0
 0
            gptid/ac9816cd-ae1f-11ed-ba90-ac1f6b61c610  ONLINE       0     0
 0
            gptid/ac92672d-ae1f-11ed-ba90-ac1f6b61c610  ONLINE       0     0
 0
errors: No known data errors
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:04 with 0 errors on Tue Nov  7 03:45:04 2023
  pool: boot-pool
 state: ONLINE
root@TrueNas[~]# camcontrol devlist
<WDC WD6003FFBX-68MU3N0 83.00A83>  at scbus1 target 0 lun 0 (ada0,pass0)
<ST5000LM000-2U8170 0001>          at scbus2 target 0 lun 0 (ada1,pass1)
<WDC WD6003FFBX-68MU3N0 83.00A83>  at scbus3 target 0 lun 0 (ada2,pass2)
<WDC WD6003FFBX-68MU3N0 83.00A83>  at scbus4 target 0 lun 0 (ada3,pass3)
<WDC WD6003FFBX-68MU3N0 83.00A83>  at scbus5 target 0 lun 0 (ada4,pass4)
<AHCI SGPIO Enclosure 2.00 0001>   at scbus6 target 0 lun 0 (ses0,pass5)
man-u-l
zpool status cut out the last part:
Last login: Tue Nov 7 08:07:57 on pts/2
FreeBSD 13.1-RELEASE-p7 n245428-4dfb91682c1 TRUENAS
TrueNAS (c) 2009-2023, iXsystems, Inc.
All rights reserved.
TrueNAS code is released under the modified BSD license with some
files copyrighted by (c) iXsystems, Inc.
For more information, documentation, help or support, go here: http://truenas.com
Welcome to TrueNAS
Warning: the supported mechanisms for making configuration changesare the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAYRESULT IN SYSTEM FAILURE.
NAME STATE READ WRITE CKSUM
NAS ONLINE 0 0 0
UM
NAS ONLINE 0 0
0
raidz2-0 ONLINE 0 0
pool: NAS
state: ONLINE
UM
NAS ONLINE 0 0
0
raidz2-0 ONLINE 0 0
pool: NAS
state: ONLINE
UM
NAS ONLINE 0 0
0
raidz2-0 ONLINE 0 0
0
0
0
0
0
pool: boot-pool
state: ONLINE
boot-pool ONLINE 0 0 0
nvd0p2 ONLINE 0 0 0
root@TrueNas[~]#
Davvo
Davvo
I have no idea what the command output you're posting means, as it's a mess--commands are duplicated, nonsensical syntax, etc. But notably absent is anything that looks like a single-disk pool. So what's the output of zpool import?
man-u-l
root@TrueNas[~]# zpool import
   pool: TimeMachine 4Tb
  state: UNAVAIL
status: One or more devices contains corrupted data.
 action: The pool cannot be imported due to damaged devices or data.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-5E
        TimeMachine 4Tb  UNAVAIL  insufficient replicas
          ada1           UNAVAIL  invalid label
root@TrueNas[~]#
man-u-l
Are you sure you have an offline pool? Everything looks good to me.
I know this is weird, here are a couple screen shots:
man-u-l
Like I said at the start I dont care much about the data, I will like to "Connect the new 5Tb drive to that existing pool so I dont loose the settings for that share and the storage settings"
Davvo
You can't do that unless you still have the old drive untouched and you reattach it to the system.
I would suggest destroying that pool after copying the shares and ACL configs.
