As I'm experiencing the same; here is my dmesg output. PS. I don't have USB3 and there are no unused devices in the BIOS I could think of.
# dmesg
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.1-STABLE #0 r+16f6355: Tue Aug 27 00:38:40 PDT 2013
    root@build.ixsystems.com:/tank/home/jkh/src/freenas/os-base/amd64/tank/home/        jkh/src/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
can't re-use a leaf (geom_mirror)!
module_register: module g_mirror already exists!
Module g_mirror failed to register: 17
CPU: AMD Athlon(tm) II Neo N36L Dual-Core Processor (1297.87-MHz K8-class CPU)
  Origin = "AuthenticAMD"  Id = 0x100f63  Family = 0x10  Model = 0x6  Stepping =        3
  Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C        MOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
  Features2=0x802009<SSE3,MON,CX16,POPCNT>
  AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!        >
  AMD Features2=0x8377f<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,Prefetch,OSVW,IBS,SKI        NIT,WDT,NodeId>
  TSC: P-state invariant
real memory  = 8589934592 (8192 MB)
avail memory = 8212848640 (7832 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <HP     ProLiant>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
 cpu0 (BSP): APIC ID:  0
 cpu1 (AP): APIC ID:  1
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
aesni0: No AESNI support.
cryptosoft0: <software crypto> on motherboard
acpi0: <HP ProLiant> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of ffb80000, 80000 (3) failed
acpi0: reservation of fec10000, 20 (3) failed
acpi0: reservation of fed80000, 1000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, ddf00000 (3) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
Event timer "HPET1" frequency 14318180 Hz quality 450
Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x808-0x80b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xd000-0xd0ff mem 0xfc000000-0xfdffffff,0        xfe7f0000-0xfe7fffff,0xfe600000-0xfe6fffff irq 18 at device 5.0 on pci1
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 4.0 on pci0
pci2: <ACPI PCI bus> on pcib2
vge0: <VIA Networking Velocity Gigabit Ethernet> port 0xe800-0xe8ff mem 0xfe8ffc        00-0xfe8ffcff irq 16 at device 0.0 on pci2
vge0: Using 1 MSI message
miibus0: <MII bus> on vge0
ip1000phy0: <IP1001 10/100/1000 media interface> PHY 1 on miibus0
ip1000phy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000base        T-master, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
vge0: Ethernet address: 00:a1:b0:d2:f5:46
pcib3: <ACPI PCI-PCI bridge> irq 18 at device 6.0 on pci0
pci3: <ACPI PCI bus> on pcib3
bge0: <HP NC107i PCIe Gigabit Server Adapter, ASIC rev. 0x5784100> mem 0xfe9f000        0-0xfe9fffff irq 18 at device 0.0 on pci3
bge0: CHIP ID 0x05784100; ASIC REV 0x5784; CHIP REV 0x57841; PCI-E
miibus1: <MII bus> on bge0
brgphy0: <BCM5784 10/100/1000baseT PHY> PHY 1 on miibus1
brgphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-m        aster, 1000baseT-FDX, 1000baseT-FDX-master, auto, auto-flow
bge0: Ethernet address: d8:d3:85:b3:a5:c3
ahci0: <ATI IXP700 AHCI SATA controller> port 0xc000-0xc007,0xb000-0xb003,0xa000        -0xa007,0x9000-0x9003,0x8000-0x800f mem 0xfe5ffc00-0xfe5fffff irq 19 at device 1        7.0 on pci0
ahci0: AHCI v1.20 with 6 3Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ohci0: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe5fe000-0xfe5fefff irq 18 a        t device 18.0 on pci0
usbus0 on ohci0
ehci0: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe5ff800-0xfe5ff8ff irq        17 at device 18.2 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
ohci1: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe5fd000-0xfe5fdfff irq 18 a        t device 19.0 on pci0
usbus2 on ohci1
ehci1: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe5ff400-0xfe5ff4ff irq        17 at device 19.2 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci1
pci0: <serial bus, SMBus> at device 20.0 (no driver attached)
isab0: <PCI-ISA bridge> at device 20.3 on pci0
isa0: <ISA bus> on isab0
pcib4: <ACPI PCI-PCI bridge> at device 20.4 on pci0
pci4: <ACPI PCI bus> on pcib4
ohci2: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe5fc000-0xfe5fcfff irq 18 a        t device 20.5 on pci0
usbus4 on ohci2
ohci3: <AMD SB7x0/SB8x0/SB9x0 USB controller> mem 0xfe5fb000-0xfe5fbfff irq 18 a        t device 22.0 on pci0
usbus5 on ohci3
ehci2: <AMD SB7x0/SB8x0/SB9x0 USB 2.0 controller> mem 0xfe5ff000-0xfe5ff0ff irq        17 at device 22.2 on pci0
usbus6: EHCI version 1.0
usbus6 on ehci2
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb4
acpi_button0: <Power Button> on acpi0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
ppc0: cannot reserve I/O port range
acpi_throttle0: <ACPI CPU Throttling> on cpu0
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, loggi        ng disabled
DUMMYNET 0xfffffe00029425c0 with IPv6 initialized (100409)
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
load_dn_sched dn_sched RR loaded
The GEOM class MIRROR is already loaded.
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
usbus4: 12Mbps Full Speed USB v1.0
usbus5: 12Mbps Full Speed USB v1.0
usbus6: 480Mbps High Speed USB v2.0
ugen0.1: <ATI> at usbus0
uhub0: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <ATI> at usbus1
uhub1: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen2.1: <ATI> at usbus2
uhub2: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <ATI> at usbus3
uhub3: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
ugen4.1: <ATI> at usbus4
uhub4: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus4
ugen5.1: <ATI> at usbus5
uhub5: <ATI OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus5
ugen6.1: <ATI> at usbus6
uhub6: <ATI EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus6
uhub4: 2 ports with 2 removable, self powered
uhub5: 4 ports with 4 removable, self powered
uhub0: 5 ports with 5 removable, self powered
uhub2: 5 ports with 5 removable, self powered
uhub6: 4 ports with 4 removable, self powered
uhub1: 5 ports with 5 removable, self powered
uhub3: 5 ports with 5 removable, self powered
ugen3.2: <PEAK III> at usbus3
umass0: <PEAK III Flash Drive, class 0/0, rev 2.00/1.00, addr 2> on usbus3
ugen1.2: <JMicron> at usbus1
umass1: <Storage> on usbus1
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <SAMSUNG HD204UI 1AQ10001> ATA-8 SATA 2.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada2: Previously was known as ad8
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada3: Previously was known as ad10
ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
ada4: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada4: Previously was known as ad12
ada5 at ahcich5 bus 0 scbus5 target 0 lun 0
ada5: <TOSHIBA DT01ACA300 MX6OABB0> ATA-8 SATA 3.x device
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada5: Previously was known as ad14
da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
SMP: AP CPU #1 Launched!
da0: <PEAK III Flash Drive 0.00> Removable Direct Access SCSI-2 device
da0: 40.000MB/s transfers
da0: 1928MB (3948544 512 byte sectors: 255H 63S/T 245C)
da0: quirks=0x2<NO_6_BYTE>
da1 at umass-sim1 bus 1 scbus7 target 0 lun 0
da1: <WDC WD32 00BEVT-60ZCT0 12.0> Fixed Direct Access SCSI-2 device
da1: 40.000MB/s transfers
da1: 305245MB (625142448 512 byte sectors: 255H 63S/T 38913C)
da1: quirks=0x2<NO_6_BYTE>
Timecounter "TSC" frequency 1297870623 Hz quality 800
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)
GEOM_ELI: Device da1p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI:     Crypto: software
Solaris: WARNING: Disk, '/dev/da1p3', has a block alignment that is larger than        the pool's alignment
da0 is FreeNAS USB stick of 2 Gb; da1 is a 2,5 inch HDD inside a USB case. ada0 - ada5 are my disks. I have been replacing those with Toshiba's instead of the Samsung F4G's due to upgrade and failing disks. I hope I'm not stealing this thread.
