shows my network card but he is not active
iorifly
Freenas8 installed on my machine it shows my network card but he is not active connection to the network! it seems that my card is dead! Now I have a two and a offbord onbord both disabled!
Michael Mielko
I have a similar situation. my onboard LAN seems dead to FreeNAS but the ethernet card I dropped in is reconized and used. Both are reconized, but the onboard lan can't grab an IP from the DHCP pool (DD-WRT) ....
Milhouse
I can't see either of you getting much help unless you provide hardware specs (CPU, motherboard, network card), dmesg output (of the network adapter being detected), what version of FreeNAS you are using (8.0.1-RELEASE? i386 or AMD/x64?) etc.
Have you checked the FreeBSD message boards? FreeNAS is based on FreeBSD 8.2, so if FreeBSD 8.2 doesn't support your hardware there's not much chance of FreeNAS doing so.
