Hi Guys,
to keep it short: I have to replace a Mirror Pool and want also to decrease it.
After reading into it i made the choice to choose a 2-Mirror Setting.
First i was at a ZRaid1 - then ZRaid2 but the benefit of expanding easily a Mirror Pool by adding another pair of disks sounds like the best solution.
That being said i installed the 4 new disks.
Question now: Is it a good solution to just add the new disks as VDevs to the existing Data Pool and wait for resilvering and then remove the two disks i want to replace or should i start with a new Pool instead and use the replication tasks to copy the Data?
Thanks for reply!
Thanks for reply!
