The problems:
- wrong driver version
installed 515
needed 470
- jellyfin won't start
Error: failed to start container "jellyfin": Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy' nvidia-container-cli: initialization error: nvml error: driver not loaded: unknown
- the menu for GPU allocation in jellyfin only allows 0 nvidia gpus independently of it being reserved or not in System -> Advanced -> GPU Allocation
The hardware:
Motherboard: Gigabyte GA-EX58-UD5-rev-10
CPU: i7-920
RAM: 16GB
Disks:
- WD3200BEKT (boot)
- WD5000AAKS (mainpool)
- WD5000AACS (mainpool)
GPUs:
- NVIDIA 9800GT (gigabyte)
- NVIDIA GTX660 (msi)
A dedicated guide for installing jellyfin on TrueNAS that actually worked would be apreciated (specially with nvidia transcoding on old cards)
help!
and
thanks!
installed 515
needed 470
The hardware:
CPU: i7-920
RAM: 16GB
Disks:
- WD3200BEKT (boot)
GPUs:
help!
and
thanks!
