Set Up Movies
SweetAndLow
Sweet'NASty
So if that is not working.
Dude you keep doing this wrong. You did /media so that should be exactly the path you use in Plex. Don't capitalize it, don't add spaces, don't add extra paths unless they really exist.
Sergioik
Ok, I understood, but when I put /media, on the way, it really worked, but it on the screen Bibliotecnia photo, movies, TV shows, and as photos.
SweetAndLow
Sweet'NASty
Ok now that you see it does work you can try adding paths for each of your library types. Just make sure it's a real path and you do the exact name of that path.
Sergioik
Ok, thank you very much for the help, just to finish I made changes in the jails, this way for music works correctly but for photo library it finds all.
Sergioik
I really appreciate your attention and help, just to finish I have to create entries in the jails, for each Library, with the following photo.
