Bikerchris
- Mar 22, 2020
Hello all,
Try as I might, I just had a small question, very sorry to trouble you.
I've installed SyncThing many times on many TrueNAS and formally FreeNAS installs without issue. Over the past 3-4 days however, I've been unable to install it as a plugin or jail.
Initially I tried the simple plugin method and received this message:
I then tried to do it manually, as in create a jail, then
After this I thought perhaps I have network issues, so I ping'd google with success, I also tried
I understand that installing in any other way can affect the stability of the system in general, I just wish confirmation that I should just patiently wait until it's available again? I'm perfectly fine waiting, just seeking clarification.
Many thanks and look forward to any responses.
Chris
Error: syncthing had a failure Exception: RuntimeError Message: pkg error: - syncthing : Refusing to fetch artifact and run post_install.sh! Partial plugin destroyed
pkg install syncthing
(after pkg update) and received this message:root@syncthing:/bin # pkg install syncthing Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. pkg: No packages available to install matching 'syncthing' have been found in the repositories
pkg install netdata
and that offered the download/install as usual.I understand that installing in any other way can affect the stability of the system in general, I just wish confirmation that I should just patiently wait until it's available again? I'm perfectly fine waiting, just seeking clarification.
Chris
