Hey All,
I'm getting significantly lower read speeds compared to write speeds, and I'm seeking insights or suggestions to resolve this.
System Setup:
Test Procedure and Results:
Issue: While I'm unsure whether the write speeds are what you might expect for this setup, I believe read speeds are significantly lower than they should be.
Are there specific ZFS settings or TrueNAS configurations that I should check or modify to improve non-cached read performance?
Any assistance or guidance from the community would be greatly appreciated.
Thank you in advance!
System Setup:
- TrueNAS running as VM with 16 Cores (EPYC 75F3 32-Core) and 124gb RAM
- 4 VDEV's of 6 drives in Raidz2
- Dataset for testing:
speedtest(created specifically for this purpose with compression turned off). - ZFS Cache Setting: Set
primarycache=metadatato disable data caching (only applied to the speedtest dataset).
- Write Test:
- Command:
dd if=/dev/zero of=/mnt/bender/speedtest/tmp.dat bs=2048k count=50k - Result: 107374182400 bytes transferred in 56.531521 secs (approx. 1.899 GB/s)
- Command:
- Read Test:
- Command:
dd if=/mnt/bender/speedtest/tmp.dat of=/dev/null bs=2048k count=50k - Result: 107374182400 bytes transferred in 254.130370 secs (approx. 0.422 GB/s)
- Command:
