Feb 17 22:03:52 freenas (da5:mpr0:0:47:0): WRITE(10). CDB: 2a 00 5a 36 41 f0 00 01 00 00
Feb 17 22:03:52 freenas (da5:mpr0:0:47:0): CAM status: SCSI Status Error
Feb 17 22:03:52 freenas (da5:mpr0:0:47:0): SCSI status: Check Condition
Feb 17 22:03:52 freenas (da5:mpr0:0:47:0): SCSI sense: DATA PROTECT asc:20,2 (Access denied - no access rights)
Feb 17 22:03:52 freenas (da5:mpr0:0:47:0): Error 1, Unretryable error
Feb 17 22:03:52 freenas (da4:mpr0:0:46:0): WRITE(10). CDB: 2a 00 5a 36 41 f0 00 01 00 00
Feb 17 22:03:52 freenas (da4:mpr0:0:46:0): CAM status: SCSI Status Error
Feb 17 22:03:52 freenas (da4:mpr0:0:46:0): SCSI status: Check Condition
Feb 17 22:03:52 freenas (da4:mpr0:0:46:0): SCSI sense: DATA PROTECT asc:20,2 (Access denied - no access rights)
Feb 17 22:03:52 freenas (da4:mpr0:0:46:0): Error 1, Unretryable error
Just recently finished my new build with 12 x 800gb HUSMM1680ASS201 configured as raid 10 in a supermicro case with sas 3 backplane and LSI 9300-8I HBA.
Everything was well for about a month or so, until recently it is starting to spew out similar error as listed above.
When the error first show up about a week ago, I tried destroying the pool, secure erasing individual drive and recreating the pool, but the issue return after about a week or so. Initially I was running the latest version of 11.1 version, and decided to upgrade to 11.2 last weekend to see if the issue is resolved. -- no luck
The error return last night.
I did some more reading and investigation and found out that the drive I used are capable of SED and the SCSI sense error kinda led me into thinking this might be the case.
Data Protect
Data Protect is received when the device is working but locked, either a physical write lock or for Data-at-Rest encryption when the device was not yet unlocked or the band was not yet unlocked.
So I did some digging and found https://www.ixsystems.com/blog/library/using-self-encrypting-drives/
I ran the sedutil-cli --scan but everything comes as NO
Then I ran
root@freenas:~ # sedhelper unlock
All SED disks unlocked
Not sure this will solve the issue, I notice the issue usually show up when the drive are loaded in the evening during backup process.
HELP !! I am not sure what else to check, I did the basic hardware troubleshooting like replace cable, memtest etc and I think all is good to go.
Thanks
Data Protect
Then I ran
Thanks
