Scrub reveals repairs two scrubs in a row
Stux
PSU?
trsupernothing
the dual 1200 watt supermicro psu's came with the chasis, when I swapped / changed chasis I also changed psu's. My next plan now is to try a 3rd lsi card I have. Have to upgrade the firmware on it first. Only thing else I can imagine would be perhaps a drive causing interference on the sas cable (perhaps from the other vdev on the second case) (there are 2 vdevs on the second case, the one with the 6tb wd reds, and a bunch of rando 4tb drives in a vdev above it) total of 16 drives in the second chasis, chasis 1 is full 24 drives with zero read errors. oddly enough there aren't any read errors on vdev 1 of the second chasis, only vdev2
trsupernothing
Another thought I had (although I refuse to believe it) would be insufficient ram. I only have 32gb of ram for over 100tb of data. I anticipated slow transfer speeds etc to and from the box with that level of ram (transfer speeds are great through) but I've been refusing to believe that read errors from a vdev are due to lower ram amounts. I will spend another $300 on ram but have been spending every dollar on replacing drives over the past several months to try and troubleshoot that way.
SweetAndLow
Sweet'NASty
I wonder if your drives are over heating during scrubs? What is your scrub schedule does it match when you get the errors? Did you cut off the smart tests? Do you have constant scheduled runs setup?
trsupernothing
I have the scrubs set up on the 1st and 15th of every month. I ONLY get the read error email alerts during a scrub. What do you mean did I cut off the smart tests?... As in, is a smart test running while a scrub is occurring? Short tests are scheduled every 2 days, long tests twice a month. A scrub takes an average of 60 hours to complete.
SweetAndLow
Sweet'NASty
The output you provided above only showed 1 smart test ever being run. There should be a big list. I think your system is overheating and that is causing your problems. At full load you want your drives at or below 40c. If they are getting up to 60c+ things can get funky.
trsupernothing
I've had the smart tests scheduled as described above for some time now, however upon replacing drives (in an attempt to troubleshoot) i've found the need to go back and edit the schedule and select the new drives in the schedule. I know i recently went and added missing drives from the schedules (but I couldn't say which drives were missing from the schedule) The smart data I provided was from an email script I found on this forum to email me smart data ever few days. (just set this up last week) Please forgive the ignorant question, but what about what I submitted shows only 1 test.
trsupernothing
PS, thank you everyone for your responses thus far. I am very grateful for your time. I know how ungrateful people can be asking for help / bouncing ideas back and forth. I want to reinforce my gratitude for the help.
trsupernothing
Here is the total smart email output of all of my drives...
########## SMART status report for da0 drive (Western Digital Red: WD-x) ##########
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   179   178   021	Pre-fail  Always	   -	   8016
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   716
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   100   253   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   089   089   000	Old_age   Always	   -	   8719
 10 Spin_Retry_Count		0x0032   100   100   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   22
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   17
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   1172
194 Temperature_Celsius	 0x0022   108   106   000	Old_age   Always	   -	   44
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   164
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
No Errors Logged
Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
Short offline	   Completed without error	   00%	  8529		 -
########## SMART status report for da1 drive (Seagate Desktop HDD.15: Z30x) ##########
See vendor-specific Attribute list for marginal Attributes.
  1 Raw_Read_Error_Rate	 0x000f   109   099   006	Pre-fail  Always	   -	   22283488
  3 Spin_Up_Time			0x0003   091   091   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1580
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   059   053   030	Pre-fail  Always	   -	   945069250529
  9 Power_On_Hours		  0x0032   067   067   000	Old_age   Always	   -	   29219
 10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   107
183 Runtime_Bad_Block	   0x0032   099   099   000	Old_age   Always	   -	   1
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   099   000	Old_age   Always	   -	   0 0 1
189 High_Fly_Writes		 0x003a   029   029   000	Old_age   Always	   -	   71
190 Airflow_Temperature_Cel 0x0022   060   039   045	Old_age   Always   In_the_past 40 (Min/Max 25/40 #456)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   60
193 Load_Cycle_Count		0x0032   071   071   000	Old_age   Always	   -	   59426
194 Temperature_Celsius	 0x0022   040   061   000	Old_age   Always	   -	   40 (128 0 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   189
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   9592h+47m+30.841s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   305391411860
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   751616211051
No Errors Logged
Short offline	   Completed without error	   00%	 29028		 -
########## SMART status report for da2 drive (Seagate Desktop HDD.15: S3xJ) ##########
  1 Raw_Read_Error_Rate	 0x000f   117   099   006	Pre-fail  Always	   -	   148430792
  3 Spin_Up_Time			0x0003   092   092   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1516
  7 Seek_Error_Rate		 0x000f   078   060   030	Pre-fail  Always	   -	   81594905
  9 Power_On_Hours		  0x0032   081   081   000	Old_age   Always	   -	   16804
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   30
183 Runtime_Bad_Block	   0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0 0 0
189 High_Fly_Writes		 0x003a   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0022   053   051   045	Old_age   Always	   -	   47 (Min/Max 30/48)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   18
193 Load_Cycle_Count		0x0032   079   079   000	Old_age   Always	   -	   43333
194 Temperature_Celsius	 0x0022   047   049   000	Old_age   Always	   -	   47 (0 16 0 0 0)
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   217
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   7176h+46m+01.232s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   88154693564
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1807420685787
No Errors Logged
Short offline	   Completed without error	   00%	 16613		 -
########## SMART status report for da3 drive (Seagate Desktop HDD.15: Z3xN) ##########
  1 Raw_Read_Error_Rate	 0x000f   117   099   006	Pre-fail  Always	   -	   139773184
  4 Start_Stop_Count		0x0032   098   098   020	Old_age   Always	   -	   2502
  7 Seek_Error_Rate		 0x000f   080   060   030	Pre-fail  Always	   -	   102060727
  9 Power_On_Hours		  0x0032   067   067   000	Old_age   Always	   -	   29089
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   110
189 High_Fly_Writes		 0x003a   044   044   000	Old_age   Always	   -	   56
190 Airflow_Temperature_Cel 0x0022   056   045   045	Old_age   Always   In_the_past 44 (Min/Max 27/45 #5)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   66
193 Load_Cycle_Count		0x0032   069   069   000	Old_age   Always	   -	   62610
194 Temperature_Celsius	 0x0022   044   055   000	Old_age   Always	   -	   44 (128 0 0 0 0)
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   180
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   9059h+57m+47.771s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   109473993564
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   643944800099
No Errors Logged
Short offline	   Completed without error	   00%	 28898		 -
########## SMART status report for da4 drive (Western Digital Red: WD-Wx) ##########
  3 Spin_Up_Time			0x0027   190   187   021	Pre-fail  Always	   -	   9466
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   136
  9 Power_On_Hours		  0x0032   090   090   000	Old_age   Always	   -	   7928
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   38
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   30
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   937
194 Temperature_Celsius	 0x0022   103   098   000	Old_age   Always	   -	   49
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   131
No Errors Logged
Short offline	   Completed without error	   00%	  7737		 -
########## SMART status report for da5 drive (Western Digital Red: WD-WCCxx) ##########
  3 Spin_Up_Time			0x0027   182   181   021	Pre-fail  Always	   -	   7900
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   17
  9 Power_On_Hours		  0x0032   096   096   000	Old_age   Always	   -	   3310
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   17
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   15
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   187
194 Temperature_Celsius	 0x0022   102   099   000	Old_age   Always	   -	   50
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   212
No Errors Logged
Short offline	   Completed without error	   00%	  3120		 -
########## SMART status report for da6 drive (Seagate Desktop HDD.15: Z30x) ##########
  1 Raw_Read_Error_Rate	 0x000f   116   099   006	Pre-fail  Always	   -	   110641872
  4 Start_Stop_Count		0x0032   098   098   020	Old_age   Always	   -	   2568
  7 Seek_Error_Rate		 0x000f   079   060   030	Pre-fail  Always	   -	   87021308
  9 Power_On_Hours		  0x0032   066   066   000	Old_age   Always	   -	   30043
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   109
189 High_Fly_Writes		 0x003a   081   081   000	Old_age   Always	   -	   19
190 Airflow_Temperature_Cel 0x0022   056   044   045	Old_age   Always   In_the_past 44 (Min/Max 28/44 #50)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   69
193 Load_Cycle_Count		0x0032   071   071   000	Old_age   Always	   -	   59842
194 Temperature_Celsius	 0x0022   044   056   000	Old_age   Always	   -	   44 (128 0 0 0 0)
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   186
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   8991h+21m+14.784s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   120758755060
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   618323866373
No Errors Logged
Short offline	   Completed without error	   00%	 29852		 -
########## SMART status report for da7 drive (Western Digital Red: WD-Wx) ##########
  3 Spin_Up_Time			0x0027   197   197   021	Pre-fail  Always	   -	   9141
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   18
  9 Power_On_Hours		  0x0032   096   096   000	Old_age   Always	   -	   3339
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   18
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   16
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   45
194 Temperature_Celsius	 0x0022   107   100   000	Old_age   Always	   -	   45
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   157
No Errors Logged
Short offline	   Completed without error	   00%	  3268		 -
########## SMART status report for da8 drive (Western Digital Red: WD-WX8x) ##########
  3 Spin_Up_Time			0x0027   203   200   021	Pre-fail  Always	   -	   8825
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   143
  9 Power_On_Hours		  0x0032   090   090   000	Old_age   Always	   -	   7927
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   787
194 Temperature_Celsius	 0x0022   108   096   000	Old_age   Always	   -	   44
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   148
No Errors Logged
########## SMART status report for da9 drive (Western Digital Red: WD-Wx) ##########
  3 Spin_Up_Time			0x0027   178   178   021	Pre-fail  Always	   -	   8066
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   19
  9 Power_On_Hours		  0x0032   095   095   000	Old_age   Always	   -	   3768
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   19
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   202
194 Temperature_Celsius	 0x0022   106   104   000	Old_age   Always	   -	   46
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   243
No Errors Logged
Short offline	   Completed without error	   00%	  3578		 -
########## SMART status report for da10 drive (Seagate Desktop HDD.15: S30x) ##########
  1 Raw_Read_Error_Rate	 0x000f   116   099   006	Pre-fail  Always	   -	   116316472
  4 Start_Stop_Count		0x0032   098   098   020	Old_age   Always	   -	   2332
  7 Seek_Error_Rate		 0x000f   078   060   030	Pre-fail  Always	   -	   83793848
  9 Power_On_Hours		  0x0032   070   070   000	Old_age   Always	   -	   26376
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   96
189 High_Fly_Writes		 0x003a   059   059   000	Old_age   Always	   -	   41
190 Airflow_Temperature_Cel 0x0022   060   042   045	Old_age   Always   In_the_past 40 (Min/Max 27/41 #525)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   62
193 Load_Cycle_Count		0x0032   071   071   000	Old_age   Always	   -	   58685
194 Temperature_Celsius	 0x0022   040   058   000	Old_age   Always	   -	   40 (0 16 0 0 0)
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   177
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   8536h+01m+45.302s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   104352362188
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   585723324803
No Errors Logged
Short offline	   Completed without error	   00%	 26185		 -
########## SMART status report for da11 drive (Seagate Desktop HDD.15: Z3x) ##########
  1 Raw_Read_Error_Rate	 0x000f   118   099   006	Pre-fail  Always	   -	   187461624
  3 Spin_Up_Time			0x0003   092   091   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1448
  7 Seek_Error_Rate		 0x000f   079   060   030	Pre-fail  Always	   -	   95774264
  9 Power_On_Hours		  0x0032   080   080   000	Old_age   Always	   -	   17569
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   82
190 Airflow_Temperature_Cel 0x0022   063   051   045	Old_age   Always	   -	   37 (Min/Max 16/38)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   74
193 Load_Cycle_Count		0x0032   097   097   000	Old_age   Always	   -	   7661
194 Temperature_Celsius	 0x0022   037   049   000	Old_age   Always	   -	   37 (0 16 0 0 0)
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   5815h+37m+49.717s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   37792856676
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1728536711363
No Errors Logged
Short offline	   Completed without error	   00%	 17500		 -
########## SMART status report for da12 drive (Seagate Desktop HDD.15: Z3x) ##########
  1 Raw_Read_Error_Rate	 0x000f   116   099   006	Pre-fail  Always	   -	   102941536
  4 Start_Stop_Count		0x0032   098   098   020	Old_age   Always	   -	   2488
  7 Seek_Error_Rate		 0x000f   080   060   030	Pre-fail  Always	   -	   102545690
  9 Power_On_Hours		  0x0032   065   065   000	Old_age   Always	   -	   30866
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   159
189 High_Fly_Writes		 0x003a   096   096   000	Old_age   Always	   -	   4
190 Airflow_Temperature_Cel 0x0022   060   039   045	Old_age   Always   In_the_past 40 (Min/Max 16/41 #157)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   122
193 Load_Cycle_Count		0x0032   071   071   000	Old_age   Always	   -	   58418
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   9942h+32m+17.397s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   47959641236
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   561545050791
No Errors Logged
Short offline	   Completed without error	   00%	 30797		 -
trsupernothing
continued....
########## SMART status report for da13 drive (Western Digital Blue: WD-Wxx) ##########
  3 Spin_Up_Time			0x0027   181   174   021	Pre-fail  Always	   -	   7908
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   225
  9 Power_On_Hours		  0x0032   091   091   000	Old_age   Always	   -	   7156
 11 Calibration_Retry_Count 0x0032   100   100   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   223
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   172
193 Load_Cycle_Count		0x0032   197   197   000	Old_age   Always	   -	   9089
194 Temperature_Celsius	 0x0022   109   087   000	Old_age   Always	   -	   43
198 Offline_Uncorrectable   0x0030   200   200   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
No Errors Logged
Short offline	   Completed without error	   00%	  7087		 -
########## SMART status report for da14 drive (Western Digital Green: WD-WCCx) ##########
  3 Spin_Up_Time			0x0027   184   178   021	Pre-fail  Always	   -	   7758
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   266
  9 Power_On_Hours		  0x0032   090   090   000	Old_age   Always	   -	   7490
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   266
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   201
193 Load_Cycle_Count		0x0032   196   196   000	Old_age   Always	   -	   12201
194 Temperature_Celsius	 0x0022   109   092   000	Old_age   Always	   -	   43
No Errors Logged
Short offline	   Completed without error	   00%	  7421		 -
########## SMART status report for da15 drive (: VKxX) ##########
  1 Raw_Read_Error_Rate	 0x000b   100   100   016	Pre-fail  Always	   -	   0
  2 Throughput_Performance  0x0005   132   132   054	Pre-fail  Offline	  -	   112
  3 Spin_Up_Time			0x0007   172   172   024	Pre-fail  Always	   -	   406 (Average 360)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   79
  5 Reallocated_Sector_Ct   0x0033   100   100   005	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000b   100   100   067	Pre-fail  Always	   -	   0
  8 Seek_Time_Performance   0x0005   128   128   020	Pre-fail  Offline	  -	   18
  9 Power_On_Hours		  0x0012   100   100   000	Old_age   Always	   -	   5712
 10 Spin_Retry_Count		0x0013   100   100   060	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   79
 22 Unknown_Attribute	   0x0023   100   100   025	Pre-fail  Always	   -	   100
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   303
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   303
194 Temperature_Celsius	 0x0002   130   130   000	Old_age   Always	   -	   46 (Min/Max 18/52)
196 Reallocated_Event_Count 0x0032   100   100   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0022   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0008   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x000a   200   200   000	Old_age   Always	   -	   0
No Errors Logged
Short offline	   Completed without error	   00%	  5642		 -
########## SMART status report for da16 drive (: VKHx) ##########
  2 Throughput_Performance  0x0005   129   129   054	Pre-fail  Offline	  -	   124
  3 Spin_Up_Time			0x0007   165   165   024	Pre-fail  Always	   -	   441 (Average 358)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   82
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   82
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   308
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   308
194 Temperature_Celsius	 0x0002   146   146   000	Old_age   Always	   -	   41 (Min/Max 17/48)
No Errors Logged
########## SMART status report for da17 drive (Seagate Desktop HDD.15: ZxF) ##########
  1 Raw_Read_Error_Rate	 0x000f   118   099   006	Pre-fail  Always	   -	   181424168
  3 Spin_Up_Time			0x0003   093   092   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1661
  7 Seek_Error_Rate		 0x000f   080   060   030	Pre-fail  Always	   -	   100972146
  9 Power_On_Hours		  0x0032   078   078   000	Old_age   Always	   -	   19707
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   108
190 Airflow_Temperature_Cel 0x0022   060   048   045	Old_age   Always	   -	   40 (Min/Max 16/41)
193 Load_Cycle_Count		0x0032   096   096   000	Old_age   Always	   -	   9418
194 Temperature_Celsius	 0x0022   040   052   000	Old_age   Always	   -	   40 (0 16 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   6292h+16m+22.848s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   52265265998
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1737073191540
No Errors Logged
Short offline	   Completed without error	   00%	 19637		 -
########## SMART status report for da18 drive (: Wx) ##########
  1 Raw_Read_Error_Rate	 0x000f   118   100   006	Pre-fail  Always	   -	   6961504
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1672
  7 Seek_Error_Rate		 0x000f   079   060   030	Pre-fail  Always	   -	   26346247290
  9 Power_On_Hours		  0x0032   077   077   000	Old_age   Always	   -	   20503
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   150
190 Airflow_Temperature_Cel 0x0022   055   047   045	Old_age   Always	   -	   45 (Min/Max 17/47)
194 Temperature_Celsius	 0x0022   045   053   000	Old_age   Always	   -	   45 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   118   100   000	Old_age   Always	   -	   6961504
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   6224 (67 249 0)
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   49747679918
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1762101389702
No Errors Logged
Short offline	   Completed without error	   00%	 20434		 -
########## SMART status report for da19 drive (Western Digital Blue: WD-Wx) ##########
  3 Spin_Up_Time			0x0027   182   175   021	Pre-fail  Always	   -	   7875
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   178
  9 Power_On_Hours		  0x0032   091   091   000	Old_age   Always	   -	   6784
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   178
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   143
193 Load_Cycle_Count		0x0032   199   199   000	Old_age   Always	   -	   3505
194 Temperature_Celsius	 0x0022   105   096   000	Old_age   Always	   -	   47
No Errors Logged
Short offline	   Completed without error	   00%	  6714		 -
########## SMART status report for da20 drive (Western Digital Green: WD-WCx) ##########
  3 Spin_Up_Time			0x0027   178   170   021	Pre-fail  Always	   -	   8058
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   287
  9 Power_On_Hours		  0x0032   090   090   000	Old_age   Always	   -	   7552
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   287
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   182
193 Load_Cycle_Count		0x0032   194   194   000	Old_age   Always	   -	   18426
194 Temperature_Celsius	 0x0022   103   094   000	Old_age   Always	   -	   49
No Errors Logged
Short offline	   Completed without error	   00%	  7483		 -
########## SMART status report for da21 drive (: VKx) ##########
  2 Throughput_Performance  0x0005   133   133   054	Pre-fail  Offline	  -	   109
  3 Spin_Up_Time			0x0007   167   167   024	Pre-fail  Always	   -	   417 (Average 369)
  9 Power_On_Hours		  0x0012   100   100   000	Old_age   Always	   -	   5713
194 Temperature_Celsius	 0x0002   115   115   000	Old_age   Always	   -	   52 (Min/Max 17/59)
197 Current_Pending_Sector  0x0022   100   100   000	Old_age   Always	   -	   8
No Errors Logged
Short offline	   Completed without error	   00%	  5643		 -
########## SMART status report for da22 drive (: Vx) ##########
  2 Throughput_Performance  0x0005   130   130   054	Pre-fail  Offline	  -	   120
  3 Spin_Up_Time			0x0007   160   160   024	Pre-fail  Always	   -	   411 (Average 410)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   81
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   81
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   307
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   307
194 Temperature_Celsius	 0x0002   125   125   000	Old_age   Always	   -	   48 (Min/Max 18/55)
No Errors Logged
########## SMART status report for da23 drive (: W4x) ##########
  1 Raw_Read_Error_Rate	 0x000f   111   100   006	Pre-fail  Always	   -	   31373600
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1492
  7 Seek_Error_Rate		 0x000f   078   060   030	Pre-fail  Always	   -	   30610544322
  9 Power_On_Hours		  0x0032   078   078   000	Old_age   Always	   -	   19830
189 High_Fly_Writes		 0x003a   094   094   000	Old_age   Always	   -	   6
190 Airflow_Temperature_Cel 0x0022   060   049   045	Old_age   Always	   -	   40 (Min/Max 17/41)
191 G-Sense_Error_Rate	  0x0032   001   001   000	Old_age   Always	   -	   209317
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   54
193 Load_Cycle_Count		0x0032   097   097   000	Old_age   Always	   -	   6011
194 Temperature_Celsius	 0x0022   040   051   000	Old_age   Always	   -	   40 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   111   100   000	Old_age   Always	   -	   31373600
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   6506 (196 8 0)
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   34169472232
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1955181447410
No Errors Logged
Short offline	   Completed without error	   00%	 19761		 -
########## SMART status report for da24 drive (: Wx) ##########
  1 Raw_Read_Error_Rate	 0x000f   113   100   006	Pre-fail  Always	   -	   51238912
  3 Spin_Up_Time			0x0003   093   091   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1885
  7 Seek_Error_Rate		 0x000f   080   060   030	Pre-fail  Always	   -	   22019721474
  9 Power_On_Hours		  0x0032   078   078   000	Old_age   Always	   -	   19911
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   117
188 Command_Timeout		 0x0032   100   098   000	Old_age   Always	   -	   51541114904
190 Airflow_Temperature_Cel 0x0022   056   049   045	Old_age   Always	   -	   44 (Min/Max 17/45)
194 Temperature_Celsius	 0x0022   044   051   000	Old_age   Always	   -	   44 (0 15 0 0 0)
195 Hardware_ECC_Recovered  0x001a   113   100   000	Old_age   Always	   -	   51238912
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   6110 (172 195 0)
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   34740585324
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1505554765807
No Errors Logged
Short offline	   Completed without error	   00%	 19841
trsupernothing
continued...
########## SMART status report for da25 drive (Seagate Desktop HDD.15: x) ##########
  1 Raw_Read_Error_Rate	 0x000f   114   099   006	Pre-fail  Always	   -	   67146832
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   293
  7 Seek_Error_Rate		 0x000f   070   057   030	Pre-fail  Always	   -	   34458881499
  9 Power_On_Hours		  0x0032   088   088   000	Old_age   Always	   -	   10755
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   293
188 Command_Timeout		 0x0032   100   098   000	Old_age   Always	   -	   23 23 23
190 Airflow_Temperature_Cel 0x0022   056   030   045	Old_age   Always   In_the_past 44 (255 255 48 16 0)
193 Load_Cycle_Count		0x0032   077   077   000	Old_age   Always	   -	   46821
194 Temperature_Celsius	 0x0022   044   070   000	Old_age   Always	   -	   44 (0 15 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   8204h+50m+32.276s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   56264486085
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1713605432388
No Errors Logged
Short offline	   Completed without error	   00%	 10686		 -
########## SMART status report for da26 drive (Seagate Desktop HDD.15: Zx) ##########
  1 Raw_Read_Error_Rate	 0x000f   117   099   006	Pre-fail  Always	   -	   136393352
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   150
  7 Seek_Error_Rate		 0x000f   076   060   030	Pre-fail  Always	   -	   8683973648
  9 Power_On_Hours		  0x0032   088   088   000	Old_age   Always	   -	   11132
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   151
188 Command_Timeout		 0x0032   100   097   000	Old_age   Always	   -	   31 31 31
190 Airflow_Temperature_Cel 0x0022   053   035   045	Old_age   Always   In_the_past 47 (Min/Max 16/51 #32765)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   76
193 Load_Cycle_Count		0x0032   079   079   000	Old_age   Always	   -	   43130
194 Temperature_Celsius	 0x0022   047   065   000	Old_age   Always	   -	   47 (0 15 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   8099h+54m+23.154s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   104501140365
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1959229066058
No Errors Logged
Short offline	   Completed without error	   00%	 11062		 -
########## SMART status report for da27 drive (: VKx) ##########
  3 Spin_Up_Time			0x0007   169   169   024	Pre-fail  Always	   -	   408 (Average 372)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   78
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   78
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   305
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   305
194 Temperature_Celsius	 0x0002   115   115   000	Old_age   Always	   -	   52 (Min/Max 17/58)
No Errors Logged
########## SMART status report for da28 drive (: x) ##########
  2 Throughput_Performance  0x0005   131   131   054	Pre-fail  Offline	  -	   116
  3 Spin_Up_Time			0x0007   158   158   024	Pre-fail  Always	   -	   417 (Average 415)
194 Temperature_Celsius	 0x0002   125   125   000	Old_age   Always	   -	   48 (Min/Max 17/54)
No Errors Logged
########## SMART status report for da29 drive (: Wx) ##########
  1 Raw_Read_Error_Rate	 0x000f   118   100   006	Pre-fail  Always	   -	   197627528
  4 Start_Stop_Count		0x0032   099   099   020	Old_age   Always	   -	   1695
  7 Seek_Error_Rate		 0x000f   073   059   030	Pre-fail  Always	   -	   94951306302
  9 Power_On_Hours		  0x0032   079   079   000	Old_age   Always	   -	   19045
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   102
190 Airflow_Temperature_Cel 0x0022   064   054   045	Old_age   Always	   -	   36 (Min/Max 17/38)
191 G-Sense_Error_Rate	  0x0032   058   058   000	Old_age   Always	   -	   85143
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   79
193 Load_Cycle_Count		0x0032   097   097   000	Old_age   Always	   -	   7935
194 Temperature_Celsius	 0x0022   036   046   000	Old_age   Always	   -	   36 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   118   100   000	Old_age   Always	   -	   197627528
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   5914 (203 145 0)
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   24513428196
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1484386589463
No Errors Logged
Short offline	   Completed without error	   00%	 18976		 -
########## SMART status report for da30 drive (Seagate Desktop HDD.15:x) ##########
  1 Raw_Read_Error_Rate	 0x000f   119   099   006	Pre-fail  Always	   -	   220072968
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   780
  7 Seek_Error_Rate		 0x000f   079   060   030	Pre-fail  Always	   -	   91939446
  9 Power_On_Hours		  0x0032   088   088   000	Old_age   Always	   -	   10790
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   123
183 Runtime_Bad_Block	   0x0032   098   098   000	Old_age   Always	   -	   2
190 Airflow_Temperature_Cel 0x0022   061   050   045	Old_age   Always	   -	   39 (Min/Max 16/40)
193 Load_Cycle_Count		0x0032   092   092   000	Old_age   Always	   -	   16673
194 Temperature_Celsius	 0x0022   039   050   000	Old_age   Always	   -	   39 (0 16 0 0 0)
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   7
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   6519h+22m+54.528s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   31546607700
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1394678652920
No Errors Logged
Short offline	   Completed without error	   00%	 10721		 -
########## SMART status report for da31 drive (Seagate Desktop HDD.15: x) ##########
  1 Raw_Read_Error_Rate	 0x000f   114   099   006	Pre-fail  Always	   -	   72265224
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   656
  7 Seek_Error_Rate		 0x000f   079   060   030	Pre-fail  Always	   -	   93187031
  9 Power_On_Hours		  0x0032   085   085   000	Old_age   Always	   -	   13512
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   656
188 Command_Timeout		 0x0032   100   098   000	Old_age   Always	   -	   14 14 14
190 Airflow_Temperature_Cel 0x0022   061   042   045	Old_age   Always   In_the_past 39 (Min/Max 16/42 #13754)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   75
193 Load_Cycle_Count		0x0032   066   066   000	Old_age   Always	   -	   69400
194 Temperature_Celsius	 0x0022   039   058   000	Old_age   Always	   -	   39 (0 15 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   8180h+04m+48.506s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   59052169036
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   1778594197086
No Errors Logged
Short offline	   Completed without error	   00%	 13443		 -
########## SMART status report for da32 drive (Western Digital Green: WD-x) ##########
  3 Spin_Up_Time			0x0027   179   170   021	Pre-fail  Always	   -	   8041
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   181
  9 Power_On_Hours		  0x0032   091   091   000	Old_age   Always	   -	   6762
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   181
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   151
193 Load_Cycle_Count		0x0032   199   199   000	Old_age   Always	   -	   3455
194 Temperature_Celsius	 0x0022   108   099   000	Old_age   Always	   -	   44
No Errors Logged
Short offline	   Completed without error	   00%	  6693		 -
########## SMART status report for da33 drive (: Vx) ##########
  3 Spin_Up_Time			0x0007   158   158   024	Pre-fail  Always	   -	   459 (Average 375)
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   77
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   77
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   304
193 Load_Cycle_Count		0x0012   100   100   000	Old_age   Always	   -	   304
194 Temperature_Celsius	 0x0002   127   127   000	Old_age   Always	   -	   47 (Min/Max 17/54)
No Errors Logged
########## SMART status report for da34 drive (: Vx) ##########
  4 Start_Stop_Count		0x0012   100   100   000	Old_age   Always	   -	   80
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   80
194 Temperature_Celsius	 0x0002   139   139   000	Old_age   Always	   -	   43 (Min/Max 17/50)
No Errors Logged
########## SMART status report for da35 drive (Western Digital Red: WDx) ##########
  3 Spin_Up_Time			0x0027   197   197   021	Pre-fail  Always	   -	   9116
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   11
  9 Power_On_Hours		  0x0032   097   097   000	Old_age   Always	   -	   2402
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   11
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   9
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   32
194 Temperature_Celsius	 0x0022   108   102   000	Old_age   Always	   -	   44
No Errors Logged
Short offline	   Completed without error	   00%	  2331		 -
########## SMART status report for da36 drive (Western Digital Red: WD-Wx) ##########
  9 Power_On_Hours		  0x0032   098   098   000	Old_age   Always	   -	   1879
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   31
194 Temperature_Celsius	 0x0022   109   103   000	Old_age   Always	   -	   43
No Errors Logged
Short offline	   Completed without error	   00%	  1808		 -
trsupernothing
continued....
########## SMART status report for da37 drive (Western Digital Red: WD-Wx) ##########
  3 Spin_Up_Time			0x0027   201   200   021	Pre-fail  Always	   -	   8933
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   9
  9 Power_On_Hours		  0x0032   098   098   000	Old_age   Always	   -	   1637
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   9
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   7
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   146
194 Temperature_Celsius	 0x0022   113   106   000	Old_age   Always	   -	   39
No Errors Logged
Short offline	   Completed without error	   00%	  1447		 -
########## SMART status report for da38 drive (Western Digital Red: WD-x) ##########
  3 Spin_Up_Time			0x0027   100   253   021	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   5
  9 Power_On_Hours		  0x0032   099   099   000	Old_age   Always	   -	   730
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   5
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   16
194 Temperature_Celsius	 0x0022   112   099   000	Old_age   Always	   -	   40
No Errors Logged
Short offline	   Completed without error	   00%	   659		 -
########## SMART status report for da39 drive (Western Digital Red: WD-Wx) ##########
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   4
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   659
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   4
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   13
194 Temperature_Celsius	 0x0022   103   100   000	Old_age   Always	   -	   49
No Errors Logged
Short offline	   Completed without error	   00%	   588		 -
SweetAndLow
Sweet'NASty
Looks like all of your drives have only ever run a single smart sir short test. You either don't have scheduled tests configured or they are configured wrong. Double check your settings.
I'm also very sure you are cooking your drives. What case so you have, what fans and their configured speed?
Bidule0hm
Server Electronics Sorcerer
Nop, that's the output of my script which keeps only the last test.
Yep, the hottest drive is at 44 °C which is already too much.
trsupernothing
Correct, I was pasting the output of the email script, I didn't realize there would be a different output from running smartcl from the shell. Here is an example of da36 from shell...
Model Family:	 Western Digital Red
Device Model:	 WDC WD60EFRX-68L0BN1
Serial Number:	WD-Wxxxxxxxx
LU WWN Device Id: 5 0014ee 20d7849c1
Firmware Version: 82.00A82
User Capacity:	6,001,175,126,016 bytes [6.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5700 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sat Jan 28 10:49:59 2017 CST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
been run.
data collection: ( 5024) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
command.
Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:  (   2) minutes.
Extended self-test routine
recommended polling time:  ( 703) minutes.
Conveyance self-test routine
recommended polling time:  (   5) minutes.
SCT capabilities:  	   (0x303d) SCT Status supported.
SCT Data Table supported.
  9 Power_On_Hours		  0x0032   098   098   000	Old_age   Always	   -	   1913
194 Temperature_Celsius	 0x0022   112   103   000	Old_age   Always	   -	   40
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	  1880		 -
# 2  Short offline	   Completed without error	   00%	  1808		 -
# 3  Short offline	   Completed without error	   00%	  1761		 -
# 4  Short offline	   Completed without error	   00%	  1712		 -
# 5  Short offline	   Completed without error	   00%	  1664		 -
# 6  Short offline	   Completed without error	   00%	  1617		 -
# 7  Short offline	   Completed without error	   00%	  1569		 -
# 8  Extended offline	Completed without error	   00%	  1559		 -
# 9  Short offline	   Completed without error	   00%	  1521		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
trsupernothing
My cases are supermicro 846E16-R1200B, which I have been running without top covers for months since I was running the sas cable from one case to the other without using an external cable / brackets (trying to reduce pain points for data errors for troubleshooting) Also my second case is not fully popluated with drives, so airflow is far less restricted below the drives (thus not forcing air through the drives that are populated. Without the top covers on, there is far less pull through the drive cages. I can increase fan speeds and seal the cases to improve temperatures for sure. (I just didn't realize these drives were getting too hot / didn't think to troubleshoot this way)
trsupernothing
Thanks for all the feedback thus far guys. I've been lazy to post on this thread (I started it back in October) because I've felt so defeated with this rig. I've just adjusted the fan settings to heavy io mode and will be sealing up the cases. I will run some temp checks on the drives and see if we've solved the problem. Like I've said previously.... I've swapped 7 drives over the past several months... the read errors have been so completely random and inconsistent... I've had a hell of a time trying to track this down. I'm gonna get these drives as icy cold as I can and see how we fair. If cool drives doesn't solve the issue, I'll post back here.
Robert Trevellyan
Pony Wrangler
It's possible some other component was suffering from excess heat generated by the drives during scrubs. Good luck!
