- Aug 16, 2011
Yes, that's what I said:That's CPU not disks
OTOH, they've added a graph of CPU temps, so maybe they're moving on this issue.
You missed part of the conversation.That's CPU not disks
Sent from my G3221 using Tapatalk
I'm having the same issue all of the sudden.@jasonhalljax The last test age is the number of days since the last SMART test has been executed. If it is over the threshold set in the script then the warn symbol will be displayed.
So I'm not sure if something is wrong or not but can you post the email and the output of the SMART info for this disk so I can see if and what's wrong please?
########## SMART status report summary for all drives ########## +------+---------------+----+-----+-----+-----+-------+-------+--------+------+------+------+-------+----+ |Device|Serial |Temp|Power|Start|Spin |ReAlloc|Current|Offline |UDMA |Seek |High |Command|Last| | | | |On |Stop |Retry|Sectors|Pending|Uncorrec|CRC |Errors|Fly |Timeout|Test| | | | |Hours|Count|Count| |Sectors|Sectors |Errors| |Writes|Count |Age | +------+---------------+----+-----+-----+-----+-------+-------+--------+------+------+------+-------+----+ |ada0 |WD-WCC4E2YZNDX7| 37 |20314| 32| 0| 0| 0| 0| 0| N/A| N/A| N/A| 6| |ada1 |WD-WCC7K0XNAULA| 36 | 4153| 9| 0| 0| 0| 0| 0| N/A| N/A| N/A| 6| |ada2 ?|WD-WCC4E5KJ3Y0L| 41 |20315| 32| 0| 0| 0| 0| 0| N/A| N/A| N/A| 7| |ada3 |WD-WCC4E1EFA9E6| 40 |20314| 32| 0| 0| 0| 0| 0| N/A| N/A| N/A| 6| |ada4 |WD-WCC4E6HZTD6X| 40 | 3207| 10| 0| 0| 0| 0| 0| N/A| N/A| N/A| 7| |ada5 |WD-WCC4E7SD0Z2F| 40 |20315| 34| 0| 0| 0| 0| 0| N/A| N/A| N/A| 7| +------+---------------+----+-----+-----+-----+-------+-------+--------+------+------+------+-------+----+
Thanks for your answer, I will try it. I am running the latest 11.1 stable. I am right with my thoughts I need to use all the scripts on the first page to get all the functions e.g.. hdd and cpu temp, backup config and so on?@jasonhalljax No problem.
@ArgaWoW All the info is in the first post of this thread https://forums.freenas.org/index.ph...d-identification-and-backup-the-config.27365/ ;)
I wanted to share my scripts because I think I'm not the only one who wants to monitor his FreeNAS server a bit more closely and in a more personalized way than the automatic nightly emails would do.
Feb 5 10:36:20 freenas daemon[3235]: 2018/02/05 10:36:20 [WARN] agent: Check 'freenas_health' is now warning Feb 5 10:36:46 freenas smartd[18558]: Unable to register device /dev/da0 (no Directive -d removable). Exiting
Failed conversion of ``1-on-Thu_Feb'' using format ``%Y-%b-%e_%H:%M:%S'' date: illegal time format usage: date [-jnRu] [-d dst] [-r seconds] [-t west] [-v[+|-]val[ymwdHMS]] ... [-f fmt date | [[[[[cc]yy]mm]dd]HH]MM[.ss]] [+format] Failed conversion of ``1-on-Thu_Feb'' using format ``%Y-%b-%e_%H:%M:%S'' date: illegal time format usage: date [-jnRu] [-d dst] [-r seconds] [-t west] [-v[+|-]val[ymwdHMS]] ... [-f fmt date | [[[[[cc]yy]mm]dd]HH]MM[.ss]] [+format]
You might have found the answer with a search, but here is the link:Does anybody know why? Is it related to the scripts or the system itself??
You can pull the FreeNAS version from this text file on your system: \etc\version. Mine contains this text:I wrote a short script to email me this information each night ...
kern.ostype: FreeBSD
kern.osrelease: 11.1-STABLE
kern.osrevision: 199506
kern.version: FreeBSD 11.1-STABLE #2 r321665+366f54a78b2(freenas/11.1-stable): Wed Mar 21 23:04:13 UTC 2018
This info is pulled from sysctl -a by various grep commands. I would like to add the latest update version (U4) but I can't seem to find that in the sysctl dump. Is this information available somewhere?
root@bandit:/etc # cat version FreeNAS-11.1-U4 (89e3d93bc) root@bandit:/etc #
