Resource icon
Scripted installation of Nextcloud 28 in iocage jail 2018-03-23
terrorbye
Hello now i am getting this error not sure how to solve it
not sure if it important my main isp router ip is (192.168.1.1)
while the actually router ip that ALL devices in my network use is 192.168.0.1
[ /mnt/tank/nextcloud/themes '=' /mnt/tank/nextcloud ]
+ echo 192.168.0.190
+ cut -f1 -d/
+ IP=192.168.0.190
+ cut -f2 -d/
+ NETMASK=192.168.0.190
+ [ 192.168.0.190 '=' 192.168.0.190 ]
+ NETMASK=24
+ [ 24 -lt 8 ]
+ [ 24 -gt 30 ]
+ ls -A /mnt/tank/nextcloud/config
+ cat
+ iocage create --name nextcloud -p /tmp/pkg.json -r 13.2-RELEASE 'interfaces=vnet0:bridge0' 'ip4_addr=em0|192.168.0.190/24' 'defaultrouter=192.168.0.1' 'boot=on' 'host_hostname=nextcloud' 'vnet=on'
nextcloud successfully created!
Stopped nextcloud due to VNET failure
+ echo 'Failed to create jail
+ exit 1
Command exit status: 1
and this i my config file:
JAIL_IP="192.168.0.190"
DEFAULT_GW_IP="192.168.0.1"
INTERFACE="em0"
POOL_PATH="/mnt/tank/nextcloud"
TIME_ZONE="Asia/Riyadh"
HOST_NAME="truenas.XXXX.com"
STANDALONE_CERT=1
CERT_EMAIL="pm@xxxx.com
COUNTRY_CODE="SA"
DB_PATH=" /mnt/tank/nextcloud/db"
FILES_PATH=" /mnt/tank/nextcloud/files"
CONFIG_PATH=" /mnt/tank/nextcloud/config"
THEMES_PATH=" /mnt/tank/nextcloud/themes"
victort
+ cut -f1 -d/
+ IP=192.168.0.190
+ cut -f2 -d/
+ NETMASK=24
+ [ 24 -lt 8 ]
+ [ 24 -gt 30 ]
+ cat
+ exit 1
INTERFACE="em0"
STANDALONE_CERT=1
COUNTRY_CODE="SA"
You have 192.168.0.1 as your gateway in your config file, but you state above that you router (gateway) is 192.168.1.1
Is your subnet larger that /24?
terrorbye
I have 2 routers one form my isp that is crappy and basically use to convert fiber to ethenert (192.168.1.1) and my second router(192.168.0.1) with port forward from to use and works as i openvpn works
as for my subnet, how don't the only thing i found to subnet is this in my gateway (255.255.255.0)
victort
Your issue is likely the INTERFACE variable. Remove it from your config file.
terrorbye
so it started istalling then failed, then did it 3 more times before come with an error
Installing pkg...
pkg failed to install, retry #1
pkg failed to install, retry #2
pkg failed to install, retry #3
pkg error:
- pkg-static: http://pkg.freebsd.org/FreeBSD:13:amd64/quarterly/meta.txz: No address record
pkg-static: http://pkg.freebsd.org/FreeBSD:13:amd64/quarterly/packagesite.pkg: No address record
pkg-static: http://pkg.freebsd.org/FreeBSD:13:amd64/quarterly/packagesite.txz: No address record
Please check your network
+ echo ' Failed to create jail '
+exit 1
this is the full log if it isn't enough(edited of course to hid any sentetive data):
Script started, output file is nextcloud.log
+ id -u
+ [ 0 '=' 0 ]
+ JAIL_IP=''
+ JAIL_INTERFACES=''
+ DEFAULT_GW_IP=''
+ INTERFACE=vnet0
+ VNET=on
+ POOL_PATH=''
+ JAIL_NAME=nextcloud
+ TIME_ZONE=''
+ HOST_NAME=''
+ DATABASE=mariadb
+ DB_PATH=''
+ FILES_PATH=''
+ PORTS_PATH=''
+ CONFIG_PATH=''
+ THEMES_PATH=''
+ STANDALONE_CERT=0
+ SELFSIGNED_CERT=0
+ DNS_CERT=0
+ NO_CERT=0
+ CERT_EMAIL=''
+ DL_FLAGS=''
+ DNS_SETTING=''
+ CONFIG_NAME=nextcloud-config
+ NEXTCLOUD_VERSION=27
+ COUNTRY_CODE=US
+ readlink -f ./nextcloud-jail.sh
+ SCRIPT=/root/freenas-iocage-nextcloud/nextcloud-jail.sh
+ dirname /root/freenas-iocage-nextcloud/nextcloud-jail.sh
+ SCRIPTPATH=/root/freenas-iocage-nextcloud
+ [ -e /root/freenas-iocage-nextcloud/nextcloud-config ]
+ . /root/freenas-iocage-nextcloud/nextcloud-config
+ JAIL_IP=192.168.0.190
+ DEFAULT_GW_IP=192.168.0.1
+ POOL_PATH=/mnt/tank
+ TIME_ZONE=Asia/Riyadh
+ HOST_NAME=truenas.xxxxx.com
+ STANDALONE_CERT=1
+ CERT_EMAIL=pm@xxxxx.com
+ COUNTRY_CODE=SA
+ INCLUDES_PATH=/root/freenas-iocage-nextcloud/includes
+ openssl rand -base64 12
+ ADMIN_PASSWORD=oA6iyntwQW+I/axU
+ openssl rand -base64 16
+ DB_ROOT_PASSWORD='Pw7mrLjjIp0z3fMCYUh0pA=='
+ DB_PASSWORD='rE6UnFWSCxf/bk/H7T0mqg=='
+ [ mariadb '=' mariadb ]
+ DB_NAME=MariaDB
+ freebsd-version
+ cut -d - -f -1
+ RELEASE=13.1-RELEASE
+ [ 13.1-RELEASE '=' 13.1-RELEASE ]
+ RELEASE=13.2-RELEASE
+ iocage get -p
+ zfs get -H -o value mountpoint tank/iocage
+ JAILS_MOUNT=/mnt/tank/iocage
+ [ -z 192.168.0.190 ]
+ [ -z '' ]
+ echo 'JAIL_INTERFACES not set, defaulting to: vnet0:bridge0'
+ JAIL_INTERFACES=vnet0:bridge0
+ [ -z 192.168.0.1 ]
+ [ -z /mnt/tank ]
+ [ -z Asia/Riyadh ]
+ [ -z truenas.xxxxxx.com ]
+ [ 1 -eq 0 ]
+ [ 1 -eq 1 ]
+ [ 0 -eq 1 ]
+ [ 0 -eq 1 ]
+ [ 0 -eq 1 ]
+ [ 1 -eq 1 ]
+ [ pm@xxxxxxx.com '=' '' ]
+ [ -z '' ]
+ DB_PATH=/mnt/tank/nextcloud/db
+ [ -z '' ]
+ FILES_PATH=/mnt/tank/nextcloud/files
+ [ -z '' ]
+ CONFIG_PATH=/mnt/tank/nextcloud/config
+ [ -z '' ]
+ THEMES_PATH=/mnt/tank/nextcloud/themes
+ [ -z '' ]
+ PORTS_PATH=/mnt/tank/portsnap
+ [ /mnt/tank/nextcloud/db '=' /mnt/tank/nextcloud/files ]
+ [ /mnt/tank/nextcloud/files '=' /mnt/tank/portsnap ]
+ [ /mnt/tank/portsnap '=' /mnt/tank/nextcloud/db ]
+ [ /mnt/tank/nextcloud/config '=' /mnt/tank/nextcloud/files ]
+ [ /mnt/tank/nextcloud/config '=' /mnt/tank/portsnap ]
+ [ /mnt/tank/nextcloud/config '=' /mnt/tank/nextcloud/db ]
+ [ /mnt/tank/nextcloud/themes '=' /mnt/tank/portsnap ]
+ [ /mnt/tank/nextcloud/themes '=' /mnt/tank/nextcloud/db ]
+ [ /mnt/tank/nextcloud/themes '=' /mnt/tank/nextcloud/config ]
+ [ /mnt/tank/nextcloud/db '=' /mnt/tank ]
+ [ /mnt/tank/nextcloud/files '=' /mnt/tank ]
+ [ /mnt/tank/portsnap '=' /mnt/tank ]
+ [ /mnt/tank/nextcloud/config '=' /mnt/tank ]
+ [ /mnt/tank/nextcloud/themes '=' /mnt/tank ]
+ cut -f1 -d/
+ IP=192.168.0.190
+ cut -f2 -d/
+ NETMASK=24
+ [ 24 -lt 8 ]
+ [ 24 -gt 30 ]
+ cat
+ iocage create --name nextcloud -p /tmp/pkg.json -r 13.2-RELEASE 'interfaces=vnet0:bridge0' 'ip4_addr=vnet0|192.168.0.190/24' 'defaultrouter=192.168.0.1' 'boot=on' 'host_hostname=nextcloud' 'vnet=on'
Testing Host DNS response to pkg.freebsd.org
Testing nextcloud's SRV response to pkg.freebsd.org
pkg.freebsd.org's SRV record could not be verified.
Testing nextcloud's DNSSEC response to pkg.freebsd.org
Installing pkg...
pkg error:
+exit 1
victort
Installing pkg...
pkg error:
+exit 1
+ id -u
+ [ 0 '=' 0 ]
+ JAIL_IP=''
+ DEFAULT_GW_IP=''
+ INTERFACE=vnet0
+ VNET=on
+ POOL_PATH=''
+ TIME_ZONE=''
+ HOST_NAME=''
+ DATABASE=mariadb
+ DB_PATH=''
+ FILES_PATH=''
+ PORTS_PATH=''
+ CONFIG_PATH=''
+ THEMES_PATH=''
+ STANDALONE_CERT=0
+ SELFSIGNED_CERT=0
+ DNS_CERT=0
+ NO_CERT=0
+ CERT_EMAIL=''
+ DL_FLAGS=''
+ DNS_SETTING=''
+ COUNTRY_CODE=US
+ STANDALONE_CERT=1
+ COUNTRY_CODE=SA
+ DB_NAME=MariaDB
+ freebsd-version
+ cut -d - -f -1
+ iocage get -p
+ [ -z '' ]
+ [ -z /mnt/tank ]
+ [ 1 -eq 0 ]
+ [ 1 -eq 1 ]
+ [ 0 -eq 1 ]
+ [ 0 -eq 1 ]
+ [ 0 -eq 1 ]
+ [ 1 -eq 1 ]
+ [ -z '' ]
+ [ -z '' ]
+ [ -z '' ]
+ [ -z '' ]
+ [ -z '' ]
+ cut -f1 -d/
+ IP=192.168.0.190
+ cut -f2 -d/
+ NETMASK=24
+ [ 24 -lt 8 ]
+ [ 24 -gt 30 ]
+ cat
Installing pkg...
pkg error:
+exit 1
That’s progress.
Looks like maybe a network issue. Is your default gateway and DNS set to 192.168.0.1 on the TrueNAS main config?
terrorbye
gateway:yes
nameserver was set to:
1.1.1.1
8.8.8.8
will add the 192.168.0.1 to nameserver3 and will test again
terrorbye
Well no luck saw error here are a few picture that may help
current config file:
JAIL_IP=”192.168.0.190”
POOL_PATH="/mnt/tank"
HOST_NAME=”truenas.XXXXXXXX.com”
STANDALONE_CERT=1
CERT_EMAIL=pm@xxxx.com
COUNTRY_CODE=”SA”
victort
It still looks like a network error.
It says the SRV record can’t be verified.
Are you sure network connectivity is working like it should? What happens when you manually create a jail and try to do pkg update and pkg upgrade?
terrorbye
I tried to download nextcloud via the plugins and was suprised to get an error, it didn't happen before
Error: nextcloud2 had a failure Exception: RuntimeError Message: + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped nextcloud2 due to DHCP failure Partial plugin destroyed
i wonder if it has to do with the vpn i setup to access the server remotley
terrorbye
yes google.com and my gateway can be ping,
i remember this happening to me a year ago but unfortunately i don't remember how i solved it. i think there is a problem with i switch that is connected to my truenas as the speed displayed should be 1000 and not 100 also people who use the switch always report connection problem with devices outside the switch, i will change the switch to a better one tomorrow and hopefully it might fix the issues.
tassevem
Hello, I recently installed nginx proxy manager, now I cannot access nextcloud... If I portforward on the router directly to nextcloud ip is ok and it is certified, but through the proxy manager I get a 502...
Does anyone know what is the solution?
victort
tassevem
Yes, everything is the same. I just added nginx because I need to be able to connect to more systems from outside of my network. If I point my port forwarding in the home router straight to the local IP it works great. I think it must be some caddy configuration.
victort
Did you add the Nginx IP to Nextcloud trusted proxies?
Also, in the global block of the caddy instance serving your Nextcloud install, you need to add your Nginx as a trusted proxy as well. See https://caddyserver.com/docs/caddyfile/options
The global block would look like this
  servers {
    trusted_proxies static 192.168.x.x
tassevem
Still no good...
