airflow
- May 29, 2014
10.4.14What version of MariaDB are you using?
Ok, so I now have removed my old jail with nextcloud, and trying to get run the script again to make a new jail that I can run with my reverse proxy. But I must do something wrong, as I cannot connect to nextcloud after I ran the script. Not by https to the hostname or IP directly. So my questions are:
What cert option shall I use in the config file?
I have a certificate from letsencrypt that's is pulled regularly in a docker container also residing the reverse proxy.
What hostname shall i use? As that seems important, because last time I set it up I needed to connect through the hostname and not ip.
Why can't I use the ip?
I will reverse proxy the nextcloud.my-domain.se to the jail, so I think it should be that in hostname right?
Anyway, I'm a little bit confused about the hostname and security on nextcloud. Seems like I'm hitting the wall all the time. Because of the initial security on nextcloud.
You may find steps 1 and 2 of the resource Nextcloud and OnlyOffice Integration useful.
Hello everyone,
Has anyone been able to update this jail to 12.1, I went from 11.3-p12 and tried to move to 12.1-p10 and it seems to have created an error,
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
Did I break my nextcloud sever?
Any advice would be great
If this is the wrong thread plz let me know.
Thank you,
Joe
ya that didn't seem to work,I got a Internal server error when I updated from Nextcloud 19 to 20. I restarted the jail and have not got it again. But that may not apply to your problem.
That seems to be a really big bug (that should have been a showstopper) in 12.0.but a bug happened and it deleted both my jails
If you have all the data directories still, try a reinstall using the script.What is the next steps?
Do I have to change anything here?
True, I haven't updated to 20 yet. You should be able to install 20 by editing line 298 of the script to read:Also your scripts seems to install NC.19
FILE="latest-20.tar.bz2"
Yes, you'll need to get an API Token from Cloudflare. The README describes the process.
No, actually you won't, because you're getting a standalone cert. You can safely delete the DNS_PLUGIN and DNS_ENV lines.
Code:FILE="latest-20.tar.bz2"
I'll caution, though, that as yet I haven't had time to mess with NC 20.
Yes--again, you're telling it to get the standalone cert (i.e., to use HTTP validation), so the DNS parameters are irrelevant.Will it renew automaticity even if I don't include the two lines below?
TrueNAS vs. FreeNAS shouldn't make a difference, but I'd recommend updating the script.also should I re download the script given we are in Truecore ?
git pull.Yes--again, you're telling it to get the standalone cert (i.e., to use HTTP validation), so the DNS parameters are irrelevant.
TrueNAS vs. FreeNAS shouldn't make a difference, but I'd recommend updating the script.git pull.
To be on the safe side, take a recursive snapshot of the nextcloud dataset first. That way, if it borks your data, you can roll back.I will let you know how it goes !
That means you aren't in the directory where the script is.script: ./nextcloud-jail.sh: No such file or directory
ya sorry danb35, it is installing now, just having a bad day is all.That means you aren't in the directory where the script is.
