Underwater Mike
- May 23, 2013
So, I somehow screwed up the firmware update from 8.3.0 to 9.1.1. No problem, I figured: I'll just re-import my 7-disk z2 volume and restore the configs. No such luck. Now I can't access my data, and I need some help.
I tried auto-import before restoring configs (per the documentation), and for some reason it doesn't see the volume to import. When I try to import manually, I get the following dialog (see screenie), in which I can select only one drive and none of the file system options are ZFS.
If I restore configuration BEFORE importing a volume, it shows my missing volume name in the list, but it's marked as locked (see below) and attempting to unlock it for access results in error.
Is there some simple fix I'm missing? Or am I screwed?
Thanks in advance for any help. I can't access critical data until I get this fixed.
