Hi Guys,
After my upgrade I run into some issues regarding apps.
I only have 3 apps installed (plex, emby, jellyfin), these 3 apps had the same issue as, mostly all you guys also had, that they stucked on deploying.
so after making some hotspath and kubernetes setting changes, ( see other threads in this forum) these 3 apps is back running.
They update fine, the deploy fine and they run fine.
The biggest issue, so far, I now have is that there is no available applications, no matter how many restart I make, and also restarting of middlewared dont
make any difference. All the catalog sync's runs through with succes, but available applications is empty and the blue wheel keeps on running.
Maybe some of you guys has same issue, or maybe had similar issues.
For now I think I will have to wait on the release coming out around 13-15 December, to see if this will make a difference and bring the apps back.
Cheers
Cheers
