rungekutta
 - May 11, 2016
Hi guys, first time poster so be gentle...
FreeNas looks like a great alternative for my current and future needs but I'd appreciate some feedback on current plans to validate my line of thinking.
Got nearly 2TB of data out of which 1TB is highly precious and irreplaceable. Currently using an appliance NAS of 2TB and backing up on USB disks. Ext3 used everywhere.
I'm starting to run out space so need an alternative, and ZFS and particularly its data resilience features (eg checksum) appeals to me.
Question is what hardware platform would provide more space now and ideally some scalability in the future. Without massive overkill - this is for home use and relatively light at that. After some reading on this forum I'm currently considering a Supermicro build and initial set of 2+1 4TB disks. If and when I need more space in the future I'd add another 2+1 vdev (maybe 8TB disks by then) and add to so the same zpool to expand it.
Next step after that, if relevan, would be to swap out the initial set of 2+1 disks with something larger.
Does this sound like a reasonable approach? If I understand things correctly this setup means I could lose 1 disk in each of the 2 vdevs respectively, but if I have drive failures on the wrong 2 disks at once (ie within the same vdev) I'd lose the entire zpool, correct?
Anything else obvious that I may be missing here?
Thanks!
Thanks!
