Hi, I've run out of space on my TrueNAS and I've decided to add another pool with two 2TB drives but unfortunately I've also run out of SATA connectors on my motherboard so I've decided to use a SATA expansion card with two SATA connectors (not an ideal solution, I know) to get more storage space witch brings me to my question.
Before I buy the card I'd like to ask if it is even compatible with TrueNAS. The two cards I'm considering are based on ASMEDIA ASM1061 and Marvell 88SE9125 chipsets respectively. I've searched for the answer on the internet but all the threads I could find were several years old so I'd like make sure.
I'm running TrueNAS-12.0-U5 on an old PC(not ideal, I know
CPU: FX-4300
MB: N68C-GS FX
RAM: 8GB DDR3 (max)
HDD 3x8TB
CPU: FX-4300
MB: N68C-GS FX
RAM: 8GB DDR3 (max)
HDD 3x8TB
