matt_man22
 - Mar 7, 2014
I did a clean install of version 11.2-U6 and then loaded the config from 9.2.1.8. Everything is actually running and working, except I get continuous errors when reading and writing files. The errors are:
I do not have guest access enabled, but I am browsing the share just fine with my credentials which are the user name and password of my freenas username. And reading and writing the files appears to work. But this error just keeps popping up any time a file is written.
I am the only user accessing the share at this time. Searching around I do not see much on the specific issue. Any easy fixes?
Thank you.
Sep 28 21:01:10 freenas smbd[28785]: create_connection_session_info: guest user (from session setup) not permitted to access this share (FREENAS) Sep 28 21:01:10 freenas smbd[28785]: [2019/09/28 21:01:10.713469, 1] ../source3/smbd/service.c:529(make_connection_snum) Sep 28 21:01:10 freenas smbd[28785]: create_connection_session_info failed: NT_STATUS_ACCESS_DENIED
Thank you.
