Morpheus187
- Mar 11, 2016
Hi Guys
I'm quite new to freenas, but I read a lot and finally built a machine and replace my old QNAP 859 device.
I also use a raspberry pi 2 as media device and after moving everything to the new FREENAS Box a particular large file is not playing back well, its buffering and stuttering when being served from freenas and after a few seconds it completely stops playback, from QNAP it runs fine without a delay or stuttering.
The Raspberry is getting the data via CIFS/Samba
The File copy transfer speed is not an issue, I can copy files from my windows machine with 100 MB/S ( MegaByte )
I worked the half night to solve the issue, without success, I'm pretty sure (95%) the problem has something do to with the freenas box, maybe one of you smart guys have an Idea in which direction I can look, if you need further information just ask.
Thank you very much
My Hardware:
C2750D4I Asrock Board with 32 GB ECC RAM
8x6TB WD RED Hard Disks
Gigabit Lan ( the last link to raspberry pi2 is of course 100 mbit )
Network Cards (Onboard):
07:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
08:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
Raspberry is using open elec 6.0.1
Freenas Version: FreeNAS-9.3-STABLE-201602031011
Not Virtualized
What I've already done:
- I double and triple checked all cablings and even changed the IP-Adresses Back to that the Raspberry is pulling the File from the QNAP ( which runs perfect then)
- I experimented with different CIFS Server maximum Protocol, from N1 to SMB3_00
- I experimentet with different Auxiliary parameters like socket options =TCP_NODELAY IPTOS_LOWDELAY
- I took the socket options from the QNAP smb.conf file socket options = TCP_NODELAY SO_KEEPALIVE SO_SNDBUF=262144 SO_RCVBUF=131072
- I changed the port speed to 1000 FULL on the switch
- I analyzed the network traffic via port mirroring and the only real difference I saw was a single TCP retransmission that didn't exist when I used the QNAP
- As I'm using 2 different Networks (for ESXI 192.168.2.x, for Network 192.168.1.x) I temporarely also disabled the second card, just to be sure.
- I set the switch port to 100M / HALF DUPLEX and then it works without problems, but that can't be the solution.
- I increased the buffer size of the raspberry ( see below ) and that mitigated the problem, so its kinda half-solved for now :)
Additional information:
Zpool status:
Thank you very much
My Hardware:
Not Virtualized
ifconfig:
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO>
ether d0:50:99:c0:ab:52
inet 192.168.2.5 netmask 0xffffff00 broadcast 192.168.2.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether d0:50:99:c0:ab:53
inet 192.168.1.5 netmask 0xffffff00 broadcast 192.168.1.255
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
Zpool status:
zpool status
pool: VOL1
state: ONLINE
scan: scrub repaired 0 in 2h49m with 0 errors on Wed Mar 9 13:41:46 2016
NAME STATE READ WRITE CKSUM
VOL1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/a672a7f0-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
gptid/a7922fc8-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
gptid/a8ae08fc-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
gptid/a9d6aedf-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
gptid/aaf0e30b-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
gptid/ac10aef6-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
gptid/ad2ed461-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
gptid/ae52864d-e4b4-11e5-88a3-d05099c0ab52 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h0m with 0 errors on Sat Mar 12 03:45:11 2016
freenas-boot ONLINE 0 0 0
gptid/16fc3a13-c955-11e5-958a-d05099c0ab52 ONLINE 0 0 0
