i have opened a different thread regarding my error message....
www.truenas.com
A little freenas with 2 HDDs just as storage.
OS was on usb stick, this seemsn to be corrupt.
now i want to safe the old config file from this usb stick but i am having problems to mount it properly.
i tried to import the pool on my truenas, but this seems to be not working correctly or... more likely.... i am not able to mount it properly.
as suggested in the other thread, i installed a POP!os maschine with zol and tried it there....
but when i try to mount it...
--- was formatted used an incompatible version.... ---
could someone please help me out?
i really would like to safe this config file as there was a jail with plex for a "picture-frame" and i dont want to set it up again.
this is not my maschine but my neighbours. i am using truenas myself with 2 ssd mirrored for my base-os ;)
your nhelp is really appreciated.
thanks in advance
ld-elf-so.1 not found after crash
Hi there, i have a little problem with the freenas of my neighbour. freenas 11.3-u3.2 2 sata drives usb stick as boot device. 1 jail / plugin running (plex) after a power outtake 2 days ago the server was not running, so i picked it up and hooked it to a monitor. now it shows me trying to load...
thanks in advance
