SABnzdb no SSL
Halfe
Hi.
I run a jail with 3 plugins
Sabnzdb
Couchpotato
Sonarr
Everything works perfect for a time after install but after a few days i loose possibility to connect to SSL
Ive updated FreeNAS today to correct some errors.
Build: FreeNAS-9.3-STABLE-201502162250
what is required to have SSL working and how do i check if that is installed for SABnzdb or working in jail
Joshua Parker Ruehlig
Hi.
Sabnzdb
Couchpotato
Sonarr
the sabnzbd plugin comes with SSL included. is it not working for you in a fresh install of sabnzbd?
Halfe
It works a few days or after a random reboot. No changes to permission or user access. For sab.
I've only changed that for Sonarr.
How do I get a debug log of sab. Is it activated by default in logs.
there's Logs available somewhere in the GUI, I think it's the same file you'd find in /var/db/sabnzbd/Logs
Halfe
HA. found the problem. Dunno why but permissions have changed for
/usr/local/share/sabnzbd
/ var/db/sabnzbd/
chmoded the folder 777 and now it works again.
Is there a cronjob running withing the jail that is somthing default?
/ var/db/sabnzbd/
theres no cronjob by default.
Glad it works. I personally would never change permissions for those files but instead change ownership to UID 816.
