Sabnzdb 1.1.0 not starting
wah00kid
I'm on FreeNAS-9.10.1-U2 and trying to install sabnzdb going and running into a problem.
Install and Jail creation goes fine but then in the GUI when I click to start the plugin nothing happens with no warning.
In the jail shell if I try to start the service I get the following:
root@sabnzbd_1:/ # service sabnzbd start
install: unknown group media
/usr/local/etc/rc.d/sabnzbd: WARNING: failed precmd routine for sabnzbd
Cruising around the forums I've tried a few different things including uploading the plugin directly to the jail
At one point I discovered that two of my jails had the same MAC address and so I tried to change that and create a static rule in my router but that didnt work.
Any ideas?
Joshua Parker Ruehlig
For some reason the media group was never created in your jail.
You can try installing another instance of the sabnzbd plugin.
Or this command should unset the group setting in the sabnzbd_1 jail
sysrc 'sabnzbd_group='
