I use NFS, and have all my permissions open, not the safest idea but I have my servers firewalled off from the rest of my network. I do use SMB but not much so I can't help much..
Don't upgrade the PBI through the UI. Finish whatever you're downloading, stop SAB, copy the contents of your data folder somewhere else, uninstall the old PBI, install the new PBI, copy the contents of the data folder back into place, chown those files to media:media, and then restart. It sounds like a lot of steps, but it's really not that painful.
And once you're up to the 1.0 PBI, there's a provided script to upgrade SAB to the latest release without having to install a new PBI (it's covered in the first post of this thread).
Could you also make a working Pbi of Sickbeard TPB edition? because this version only supports usenet, BTN torrents(private) TVTeam torrents(Private) and EZRSS(Currently not working).
great work btw;)
Wow, Sickbeard has alot of versions, lol. I wonder why they don't just merge all the branches together?
Anyway, I don't really have much time to work on these plugins much, around the holidays I may try to iron out some bugs but I suggest you just..
* install Sickbeard or SickBeard Anime
* delete the 'Sickbeard' folder in the /usr/pbi/sickbeard-amd64 or /usr/pbi/sb_anime-amd64 folder.
* replace the folder with the python source for Sickbeard TPB branch.
* chown -R media:media Sickbeard # set file ownership to 'media' user
Goodluck
I succeeded! Seems i had to put the permissions in couchpotato on 775 and restart it :). Couldn't find the chmod option at first but it seems it was hidden in advanced settings under general. For sickbeard I just had to set the parent directory correct, seems it takes the permissions from the parent directory and uses that for the sub directories :).
INFO - http://www.youtube.com/watch?v=ATvuk5Y4SJM
Default Ports
sabnzbd - 8080
sickbeard/anime - 8081
couchpotato - 5050
headphones - 8181
maraschino - 7000
If you are upgrading from an earlier version I highly recommend you..
-stop the service
-backup data/ folder somewhere outside of the jail (only needed if you want to backup+restore your data)
-delete all of your plugins
-delete + reinstall your plugin jail
-reinstall new version of plugin
-put data/ folder back into place (only needed if you want to backup+restore your data)
-start plugin from freenas gui
BUGS
When starting the plugins from the FreeNAS webgui, it may show that the plugin didn't start correctly. Try refreshing the page as the pidfiles sometimes take too long to be created.
FUTURE TODO
* update sabnzbd from the freenas webgui, for now from your jail run..
Code:/usr/pbi/sabnzbd-`uname -m`/sabnzbd-update.sh
* create sickbeard's autoProcessTV.cfg file from the freenas webgui, for now from your jail run..
Code:/usr/pbi/sickbeard-`uname -m`/sickbeard-autoprocess.sh
* edit sickbeard / headphones webroot from the freenas webgui
* backup/restore/updating of plugins
DOWNLOADS
64bit - http://freenas.synergames.com//browse.php?action=browse&userid=7&folder=amd64
32bit(untested) - http://freenas.synergames.com//browse.php?action=browse&userid=7&folder=i386
source - post or PM me your public key and I'll give you git access
DONATIONS
paypal = joshruehlig@gmail.com
bitcoin = 1BGC4UoTduGMhHy9ZJZqemQqBczoWJzh6Q
THANKS
Craysh - PBI hosting
Thanks to everyone who has donated thus far!
What account does the sabnzbd demon run under with the pbi?
11-18 18:58:14 INFO [tato.core.plugins.renamer] Renaming "/SABNZBD/Complete/movies/The Pianist (2002)/The.Pianist.2002.BluRay.720p.x264.DTS-WiKi.en.srt" to "/Movies/Pianist, The (2002)/The Pianist (2002) [720P].srt"11-18 18:58:14 ERROR [tato.core.plugins.renamer] Couldn't move file "/SABNZBD/Complete/movies/The Pianist (2002)/The.Pianist.2002.BluRay.720p.x264.DTS-WiKi.en.srt" to "/Movies/Pianist, The (2002)/The Pianist (2002) [720P].srt": Traceback (most recent call last):
  File "/usr/pbi/couchpotato-amd64/CouchPotato/couchpotato/core/plugins/renamer/main.py", line 423, in moveFile
    shutil.move(old, dest)
  File "/usr/pbi/couchpotato-amd64/lib/python2.7/shutil.py", line 299, in move
    copy2(src, real_dst)
  File "/usr/pbi/couchpotato-amd64/lib/python2.7/shutil.py", line 128, in copy2
    copyfile(src, dst)
  File "/usr/pbi/couchpotato-amd64/lib/python2.7/shutil.py", line 82, in copyfile
    with open(src, 'rb') as fsrc:
IOError: [Errno 2] No such file or directory: '/SABNZBD/Complete/movies/The Pianist (2002)/The.Pianist.2002.BluRay.720p.x264.DTS-WiKi.en.srt'
11-18 18:58:14 ERROR [tato.core.plugins.renamer] Failed moving the file "The.Pianist.2002.BluRay.720p.x264.DTS-WiKi.en.srt" : Traceback (most recent call last):
  File "/usr/pbi/couchpotato-amd64/CouchPotato/couchpotato/core/plugins/renamer/main.py", line 344, in scan
    self.moveFile(src, dst)
  File "/usr/pbi/couchpotato-amd64/CouchPotato/couchpotato/core/plugins/renamer/main.py", line 432, in moveFile
    raise Exception
Exception
11-18 18:58:14 INFO [tato.core.plugins.renamer] Renaming "/SABNZBD/Complete/movies/The Pianist (2002)" to "/SABNZBD/Complete/movies/_FAILED_RENAME_The Pianist (2002)"11-18 18:58:14 ERROR [tato.core.plugins.renamer] Couldn't move file "/SABNZBD/Complete/movies/The Pianist (2002)" to "/SABNZBD/Complete/movies/_FAILED_RENAME_The Pianist (2002)": Traceback (most recent call last):
    copyfile(src, dst)
IOError: [Errno 2] No such file or directory: '/SABNZBD/Complete/movies/The Pianist (2002)'
11-18 18:58:14 ERROR [tato.core.plugins.renamer] Failed moving the file "The Pianist (2002)" : Traceback (most recent call last):
  File "/usr/pbi/couchpotato-amd64/CouchPotato/couchpotato/core/plugins/renamer/main.py", line 416, in tagDir
    raise Exception
Exception
11-18 18:58:14 ERROR [   couchpotato.core.event] Error in event "app.load", that wasn't caught: Traceback (most recent call last):
  File "/usr/pbi/couchpotato-amd64/CouchPotato/couchpotato/core/event.py", line 12, in runHandler
    return handler(*args, **kwargs)
  File "/usr/pbi/couchpotato-amd64/CouchPotato/couchpotato/core/plugins/renamer/main.py", line 348, in scan
    self.tagDir(group, 'failed_rename')
    raise Exception
Exception
encoding=UTF-8 debug=False args=['--config_file', '/usr/pbi/couchpotato-amd64/data/config.ini', '--data_dir', '/usr/pbi/couchpotato-amd64/data/', '--pid_file', '/usr/pbi/couchpotato-amd64/data/couchpotato.pid', '--daemon'] app_dir=/usr/pbi/couchpotato-amd64/CouchPotato data_dir=/usr/pbi/couchpotato-amd64/data/ desktop=None options=Namespace(config_file='/usr/pbi/couchpotato-amd64/data/config.ini', console_log=False, daemon=True, data_dir='/usr/pbi/couchpotato-amd64/data/', debug=False, pid_file='/usr/pbi/couchpotato-amd64/data/couchpotato.pid', quiet=False)
BTW I am getting this error from CP when it tries to find Meta Data:
HTTPError: HTTP Error 401: Failed because you are using an unsupported version of CP, please update
How can We update to the latest version using the PBIs?
The trick is to remember which path is used inside the jail and which is used outside the jail. The path inside the jail is the one to use when configuring each program. When I first started playing with virtualisation, mount points, ownership and permissions several years ago it took me a while to wrap my head around it.Guys, I installed SAB and HP and both are working like a charm.
I'm having some problems.
First, when the SAB finishes downloading it gives a warning that the "post-processing was interrupted (can not create the folder /usr/pbi/sabnzbd-amd64/MyMusics)".
I made a mount point as the proto's video (http://www.youtube.com/watch?v=TwW3OmT3eTw) and gave permissions with code: chmod 777 /usr/pbi/headphones-amd64/MyMusics and also did chmod 777 /usr/pbi/sabnzbd-amd64/MyMusics, getting my mount point as /mnt/Volume1/MyMusics (as Source) and /mnt/Volume2/Jail/MyJail/usr/pbi/headphones-amd64/MyMusics (as destination).
I wish I had here the following scenario:
The headphones downloading to a folder called MyMusics
The couchpotato downloading to a folder called MyFilms
The sickbeard downloading to a folder called MyTV .... all them on Volume1 (outside the jail)
I believe that would be 3 Mount Points (Source/Destination)
/mnt/Volume1/MyMusics - /mnt/Volume2/Jail/MyJail/usr/pbi/headphones-amd64/MyMusics
/mnt/Volume1/MyFilms - /mnt/Volume2/Jail/MyJail/usr/pbi/couchpotato-amd64/MyFilms
/mnt/Volume1/MyTV - /mnt/Plugins/Jail/MyJail/usr/pbi/sickbeard-amd64/MyTV
Could someone help me with these problems please?
Thanks a million
Source Destination /mnt/Data/Media /mnt/Data/jail/software/media /mnt/Data/SABnzbd /mnt/Data/jail/software/usr/pbi/sabnzbd-amd64/data/Downloads
Setting Path inside SABnzbd/jail Path outside jail Default base folder: /usr/pbi/sabnzbd-amd64/data /mnt/Data/jail/software/usr/pbi/sabnzbd-amd64/data Temporary Download Folder: Downloads/incomplete /mnt/Data/SABnzbd/incomplete Completed Download Folder: Downloads/complete /mnt/Data/SABnzbd/complete Watched Folder: Downloads/watch /mnt/Data/SABnzbd/watch Post-Processing Scripts Folder: Downloads/scripts /mnt/Data/SABnzbd/scripts
[SickBeard] host=localhost port=8081 username=ABCDEF password=GHIJKL web_root= ssl=0
Setting Path inside Sick Beard/jail Path outside jail TV Download Dir /media/Video/TV /mnt/Data/Media/Video/TV
Setting Path inside Headphones/jail Path outside jail SAB Music Download Directory: /usr/pbi/sabnzbd-amd64/data/Downloads/complete /mnt/Data/SABnzbd/complete Post-Processing path to destination folder: /media/Audio/Music /mnt/Data/Media/Audio/Music
Setting Path inside CouchPotato/jail Path outside jail Rename downloaded movies From /usr/pbi/sabnzbd-amd64/data/Downloads/complete /mnt/Data/SABnzbd/complete Rename downloaded movies To /media/Video/Films /mnt/Data/Media/Video/Films Library manager Movie Folder /media/Video/Films /mnt/Data/Media/Video/Films
Setting Path inside Subsonic/jail Path outside jail Media folder called "Audio" /media/Audio /mnt/Data/Media/Audio Media folder called "Video" /media/Video /mnt/Data/Media/Video
Setting Path inside MiniDLNA/jail Path outside jail Media directory /media /mnt/Data/Media
I don't think you can, but today I worked out how to update CP to CPS manually. I took inspiration from the sabnzbd-update.sh script included with the SABnzbd plugin.
Here's how I updated CP to CPS:
* Log into FreeNAS via SSH
* Type the following commands in bold (ignore the comments which aren't in bold):
jls (to determine the current ID number of the jail - in my case the jail ID was 3; yours may differ)
jexec <jail ID> tcsh (in my case I typed jexec 3 tcsh, using the ID obtained from the previous command)
cd /usr/pbi/sabnzbd-`uname -m` (those are backticks, not single apostrophes. On a standard UK keyboard it's on the same row as the number keys, to the left of the 1.)
service couchpotato onestop (this stops the couchpotato service)
fetch https://github.com/RuudBurger/CouchPotatoServer/zipball/master (this downloads a zipped copy of the latest version of CouchPotato Server)
tar -xvf master (this expands the downloaded file into a new directory tree. Mine was called RuudBurger-CouchPotatoServer-3ecc826 - yours may vary.)
rm -r master CouchPotato/ (this deletes the downloaded zip file and the existing CouchPotato program)
mv RuudBurger-* CouchPotato (this renames the newly extracted directory tree back to the name that the couchpotato service expects to use.)
chown -R media:media CouchPotato/ (this changes the filesystem ownership of everything in that directory - I don't know if this step is actually necessary for CouchPotato, but a post somewhere in this thread said it was needed for SABnzbd, and my CPS installation seems to be working even after the change.)
service couchpotato onestart (this restarts the CouchPotato - now CouchPotato Server - service)
When you're done, type exit a couple of times to get out of both the jail and FreeNAS gracefully. Finally, reload the CP webpage in your web browser.
This is probably not the most efficient way to do things, and one day I'll copy the sabnzbd-update.sh script and edit it to do everything shown above but automatically.
mnt/DEC2010
mnt/DEC2010/JAIL/JAIL/
All non-absolute folder locations are relative to /usr/pbi/sickbeard-amd64/data
Instead of using a black hole, have you considered telling Sick Beard to integrate with SABnzbd directly?I need some help as well for jail directory issues...and your post above probably confused me a bit... ha.
I have a mount set up (not a jail, it's my NAS data, basically) at.Code:mnt/DEC2010
I have a Jail on that mount, at.Code:mnt/DEC2010/JAIL/JAIL/
I installed sickbeard and it is thoughtfully telling me:.Code:All non-absolute folder locations are relative to /usr/pbi/sickbeard-amd64/data
Now, when I go to sickbeard config under NZB black hole, I see a list of folders to chose from, but they are all starting inside the jail. I don't have any permissions to make new folders inside of the jail (even when I SSH in as root). So, my issue is, where can I put my NZB black hole, and how about any other files for that matter from my Jail programs? I assume I need to set up some kind of virtual mount, but it's blowing my mind, any help? haha.
Ideally I make a folder at: mnt/DEC2010/JFiles
And I can put everything in there.
Ideas?
Thanks.
The service command would not work because their was no file or directory "couchpotato" in /etc/rc.d
I solved this problem by opening the "freebsd" file located /usr/pbi/couchpotato-amd64/init/
I edited the appropriate fields to point it at my install directory and placed the edited file as the filename "couchpotato" at /etc/rc.d
This should also autostart the service but I have not rebooted my NAS to test it yet
ln -s /usr/pbi/couchpotato-amd64/etc/rc.d/couchpotato /usr/local/etc/rc.d/couchpotato
