Hi all,
I'm having a hard time configuring TLS for the S3 service of Freenas.
I have successfully started the S3 service, after selecting the letsencrypt certificate that I previously had for our domain. The service does not seem to throw any error, and the file
I can access the minio web interface both locally (typing the Freenas local IP address) or remotely but only by using
Trying to access with https:// leads to the following error (copied from firefox) :
But I need to secure this connection for remote file sharing... having the possibility to access the minio interface through http:// is an issue in itself, and not being able to access it with https:// is an issue too obviously.
I've tried restarting the service, I've tried rebooting the freenas, to no avail...
I'm on Freenas 11.3-U1
Anyone has a clue ?
Best,
Guillaume
/var/log/minio.log is empty.I can access the minio web interface both locally (typing the Freenas local IP address) or remotely but only by using
http://myfreenasfqdn:minio_port[/I].Trying to access with https:// leads to the following error (copied from firefox) :
SSL received a record that exceeded the maximum permissible length. Error code: SSL_ERROR_RX_RECORD_TOO_LONG
Anyone has a clue ?
Best,
Guillaume
