S.M.A.R.T Short test failed
T.J.Hammer
I received an update that a scheduled short test failed during the night.
I ran another short test (manually) and it also failed.
I have no Idea why but also my pool status say unhealthy but I did not received any email or anything, it was just a red ping on the right top corner.
I checked the shell and this is what I get:
Warning: the supported mechanisms for making configuration changes
are the TrueNAS WebUI and API exclusively. ALL OTHERS ARE
NOT SUPPORTED AND WILL RESULT IN UNDEFINED BEHAVIOR AND MAY
RESULT IN SYSTEM FAILURE.
root@truenas[~]# smartctl -a /dev/ada1
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build)
Model Family: Western Digital Black
Device Model: WDC WD4003FZEX-00Z4SA0
Serial Number: WD-WMC5D0D3CPHH
LU WWN Device Id: 5 0014ee 0596903e2
Firmware Version: 01.01A01
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Sep 29 17:54:54 2022 IDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 113) The previous self-test completed having
the read element of the test failed.
data collection: (45000) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 487) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 5
3 Spin_Up_Time 0x0027 194 141 021 Pre-fail Always - 9258
4 Start_Stop_Count 0x0032 075 075 000 Old_age Always - 25325
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 044 044 000 Old_age Always - 41594
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1176
16 Unknown_Attribute 0x0022 018 182 000 Old_age Always - 332426432413
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 394
193 Load_Cycle_Count 0x0032 192 192 000 Old_age Always - 24930
194 Temperature_Celsius 0x0022 113 097 000 Old_age Always - 39
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed: read failure 10% 41594 21273032
# 2 Short offline Completed: read failure 10% 41577 21273032
# 3 Short offline Completed without error 00% 41554 -
# 4 Extended offline Completed without error 00% 41531 -
# 5 Short offline Completed without error 00% 41522 -
# 6 Short offline Completed without error 00% 41521 -
# 7 Short offline Completed without error 00% 41505 -
# 8 Short offline Completed without error 00% 41481 -
# 9 Short offline Completed without error 00% 41457 -
#10 Short offline Completed: read failure 10% 41433 94378000
#11 Short offline Completed without error 00% 6761 -
#12 Short offline Completed without error 00% 5485 -
1 of 3 failed self-tests are outdated by newer successful extended offline self-test # 4
1 0 0 Not_testing
2 0 0 Not_testing
this is the unhealthy message:
I have I7-9700
Z390 aorus extreme
32GB DDR4 2666
750W gold Antec HCG power supply
6X 4TB WD HDD's (4 red, 2 black)
and the version of truenas is 13.0-u2
I have no idea what is wring or how to fix it, can anyone help? I'm very new to this and just wanted to create a storage for my plex and all the family photos.
Etorix
What is of relevance is the Pool>Status screen or output of zpool status.
But in any case, a drive which fails SMART tests is to be replaced (RMA if applicable).
WD Black are not optimal for NAS duty, and let's hope these WD Red are not SMR.
T.J.Hammer
thank you for your answer.
I did not buy any of the drives, or the other parts.
this is some leftovers from old machines that are no longer in use so I don't know if the red ones are SMR or not.
RMA is not an option, I think this drives are few years old now.
here is the Zpool status (sorry I'm new don't really know what to post to get help)
root@truenas[~]# zpool status
pool: Alkobi
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: scrub repaired 0B in 00:00:03 with 0 errors on Thu Sep 22 11:16:08 2022
NAME STATE READ WRITE CKSUM
Alkobi ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/448c27c5-3a43-11ed-ab80-18c04d6d9038 ONLINE 0 0 0
gptid/44b90497-3a43-11ed-ab80-18c04d6d9038 ONLINE 33 0 0
gptid/44ee3275-3a43-11ed-ab80-18c04d6d9038 ONLINE 0 0 0
gptid/44e5cbb3-3a43-11ed-ab80-18c04d6d9038 ONLINE 0 0 0
gptid/44c965d6-3a43-11ed-ab80-18c04d6d9038 ONLINE 0 0 0
gptid/44d2f088-3a43-11ed-ab80-18c04d6d9038 ONLINE 0 0 0
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:01 with 0 errors on Wed Sep 28 03:45:01 2022
boot-pool ONLINE 0 0 0
nvd0p2 ONLINE 0 0 0
root@truenas[~]#
T.J.Hammer
Just had a power outage and the system reboot, now its says that the pool is healthy but I ran fast test on all disks to be sure.
the disk in question is still failing the test and I don't know why.
Etorix
Thanks. Good news is that you have a decent raidz2 layout and ZFS has repaired errors—for now.
I would run long SMART tests on the suspect drive, and on all others for good measure.
You can still write down the serial numbers (from Pool>Disks or SMART reports) and check coverage on WD website. The only risk is finding that some of these disks are still under warranty after all…
Take this opportunity to see if the Red are EFAX (SMR, bad) or EFRX (CMR, good).
Etorix
Whatever the cause, if a drive is failing SMART tests it should be replaced and properly disposed off.
Probably because the disk is dying--what else do you think those tests are supposed to tell you? Try running a long test and see if it comes up with a different result. If not, it's time to replace the disk.
T.J.Hammer
thank you so much for your help!
I tried to check the warranty but only the 2 black ones are showing and they are out of warranty for almost 2 years now.
I can replace all the disks if needed because this are very old disks (at least 4 years of service).
What disk is the best one for storing media?
ChrisRJ
Etorix
Any CMR drive, most preferably from a NAS or Enterprise line: WD Red Plus/Pro or Gold, Seagate Ironwolf (Pro) or Exos, Toshiba N300 or MG. Pick the best price per TB.
You may use drives larger than 4 TB. Upon replacing the last drive, the pool will grow to use the added capacity.
ChrisRJ
Any NAS or enterprise storage disk should be ok. If you want to power down disks, you should check for that aspect extra, because enterprise/data center disks usually don't like this (it is simply not part of their typical "life").
Whenever I looked in my home market (Germany), to my surprise the data center-class disks were cheaper (sometimes 30-40%) than NAS disks. And I am not talking OEM/bulk-ware but the full 5 years of warranty.
If you want to stick with 4 TB drives, you need to check for SMR! On the other hand, you now have about 16 TB of net capacity. Are you happy with that capacity? And how much is electricity cost a factor in your country? Do you expect to need more capacity in the foreseeable future?
In general, I would also recommend to check the "Recommended readings" in my signature. Some things may not be relevant right now, but the more you absorb, the better your overall understanding will become.
Good luck!
T.J.Hammer
Good luck!
Hi, thanks for all the information :)
I think I wont need more storage then 16TB but I cant try and find a good deal thru my work supplier for 8TB disks.
as for the electricity, its very expensive but I cant say that's an issue.
If I say that there is an unlimited budget for the disks, what disks I should get?
I have no more space in my case it can only hold 6 disks and I try to keep the case as small as possible.
In .us at least, the best $/TB seems to be with the external WD drives. Remove the drives from the enclosures and you're good to go. No warranty that way, but they're cheap enough to buy a spare or two. At 8 TB and under there's a risk of SMR drives, but I don't think SMR is used at higher capacities (it isn't for Seagate, at least).
Etorix
Seagate Archive are SMR. Whatever the capacity, check the drives aren't SMR.
T.J.Hammer
So I did a long test for the night and now I see it failed (only on ada1 and again no email no nothing).
after the long test (manual) there was a short scheduled test for all the drive all all passed, ada1 also passed after he failed 4 shorts yesterday and 1 long over the night.
is it common to have no idea what's going on? how can I know for sure that I need to replace the disk?
I already understand that I need to replace all my disks to CMR ones and I will order 6 new 8TB WD red pro but I'm asking for the future, how can I know if I need to replace the disks when its failing and passing at the same time?
Davvo
You need to look at the output of smartctl -a /dev/ada1 and look at the values. Post the output in [CODE][/CODE].
Generally, if it fails a long test you have to change it, but you also need to monitor the values.
If you look into my signature, there is a link to a script (multireport.sh) that helps monitoring HDDs.
Jailer
Not strong, but bad
So you have a drive that's failed short tests and long tests. You've had posters here in this thread tell you that the drive is failing. What more do you need for you to be convinced that this drive needs to be replaced?
T.J.Hammer
I don't need convincing I understand that its failing and will replace it ASAP I just wanted to know if it will happened in the future what to do?
This drive now passing all tests so if a new drive will fail some test it means I need to instantly replace it?
I just don't know what is the indicator in the test itself that says replace it now.
One test is enough?
Davvo
As I said, you need to look at the datas of you want a sort of definitive answer.
If a drive consistently fails long tests, you are certain it won't last.
If a drive failed a few short tests and now is passing both long and short, keep it under observation.
joeschmuck
Old Man
I think you have been given a lot of great advice and you probably know this. It looks to me like this drive has served you well with over 41,000 hours of runtime. The only obvious errors I see is 5 Raw Read Errors and the big one is it will not pass a Short SMART test. I suspect the head positioning is out of whack or maybe the motor speed is not stable, and that is not factual data I could prove, just what I think I understand about hard drives and the data being reported. All we know for certain is the drive is failing and you know that already.
If you keep the drive (I highly recommend you replace the drive as soon as you can order a replacement), I recommend a daily SMART Short test and a weekly SMART Long/Extended test.
If a drive fails something, you must assess what the failure is and determine if the drive needs to be replaced. For example an UDMA_CRC_ERROR is often a loose of bad SATA cable, not the hard drive, but the drive reports the issue.
Will this happen again? You bet it will. The hard drives in a system should be considered 'Consumable' items. They have a limited life expectancy and the manufacturers tell you with the warranty they provide. Most 3 year warranty drives will last about 5 years with proper care, some longer, some much shorter. A hard drive are something you can bet you will need to replace eventually.
As for if this drive is SMR... If this drive has been part of your ZFS pool for quite a while without issue, then it is likely not an SMR drive. That isn't a very scientific approach but it's all I got.
