RuntimeError: maximum recursion depth exceeded
maggeler
Hi all,
i just reinstalled sickrage on my freenas box as a plugin (FreeNAS-9.10.2-U6 (561f0d7a1)) and get the following error for some reason.
That didn't happen before.
How can this be fixed?
2018-10-11 11:03:57 MAIN :: Traceback (most recent call last):
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/sickbeard/helpers.py", line 1536, in getURL
resp = session.get(url, timeout=timeout, allow_redirects=True, verify=session.verify)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/sessions.py", line 476, in get
return self.request('GET', url, **kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/sessions.py", line 464, in request
resp = self.send(prep, **send_kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/sessions.py", line 602, in send
history = [resp for resp in gen] if allow_redirects else []
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/sessions.py", line 195, in resolve_redirects
allow_redirects=False,
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/sessions.py", line 576, in send
r = adapter.send(request, **kwargs)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/cachecontrol/adapter.py", line 46, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/adapters.py", line 370, in send
timeout=timeout
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/packages/urllib3/connectionpool.py", line 544, in urlopen
body=body, headers=headers)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/packages/urllib3/connectionpool.py", line 341, in _make_request
self._validate_conn(conn)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/packages/urllib3/connectionpool.py", line 762, in _validate_conn
conn.connect()
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/packages/urllib3/connection.py", line 245, in connect
cert = self.sock.getpeercert()
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/packages/urllib3/contrib/pyopenssl.py", line 251, in getpeercert
for value in get_subj_alt_name(x509)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/requests/packages/urllib3/contrib/pyopenssl.py", line 152, in get_subj_alt_name
asn1Spec=general_names)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/pyasn1/codec/ber/decoder.py", line 792, in __call__
stGetValueDecoder, self, substrateFun
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/pyasn1/codec/ber/decoder.py", line 367, in valueDecoder
component, head = decodeFun(head, asn1Spec)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/pyasn1/codec/ber/decoder.py", line 415, in valueDecoder
r = self._createComponent(asn1Spec, tagSet)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/pyasn1/codec/ber/decoder.py", line 37, in _createComponent
return asn1Spec.clone()
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/pyasn1/type/base.py", line 203, in clone
r = self.__class__(self._componentType, tagSet, subtypeSpec, sizeSpec)
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/pyasn1/type/univ.py", line 712, in __init__
self, componentType, tagSet, subtypeSpec, sizeSpec
File "/usr/pbi/sickrage-amd64/share/sickrage/SickRage/lib/pyasn1/type/base.py", line 156, in __init__
Asn1ItemBase.__init__(self, tagSet, subtypeSpec)
TheDubiousDubber
Same issue here. I'm guessing its an issue with 9.10 plugin being too far out of date? Looks like it is reaching out to rawgit which is EOL.
CHECKVERSION :: We can't proceed with the update. Unable to check remote DB version. Error: AssertionError('Empty response from http://cdn.rawgit.com/SickRage/SickRage/ea0e19e2575ba4186d9ffc423d63a0faa0ad0ff9/sickbeard/databases/mainDB.py',)
